Pinto for sale
Date: 04/19/2017 10:15 am
71-73 Rear valance panel
Date: 01/14/2021 06:54 pm
Date: 08/01/2023 06:53 pm
Brake rotors
Date: 03/24/2017 09:02 pm
1980 pinto wagon for sale
Date: 12/11/2017 12:13 am
Drip rail chrome
Date: 01/14/2017 09:18 am
2 Station Wagons for sale
Date: 04/20/2018 11:10 am
Wanted 71-73 Pinto grill
Date: 03/09/2019 10:45 pm
1977 Front Sump 2.3 Oil Pan
Date: 09/14/2018 11:42 pm
  • Total Topics: 16,268
  • Online today: 195
  • Guests: 163
  • Total: 163
Installation of an Explorer V6 in a Cruisin Wagon?
Started by vintageracer, June 22, 2012, 09:20:18 AM
Grumpy
vintageracer
The 4.0 Explorer engine barely weights anything less than a small block Ford, and is even heavier than a small Ford with aluminum heads(450 or so pounds for each+-25 pounds). That is the main reason I gave up on putting a 3.2 SHO motor in mine(480 pounds). Also, the 4.o in the Explorer is known to have "issues" in reliability, fuel mileage and roughness, I would not recomend it. Better would be one of the later Ranger 3.0 v6 engines. They are based on the old 2.8 that was available in the Pinto and most of them are fuel injected. You'll only get about 170 hp stock, but just a cam change and tune would get you to 200. Another good choice would be any of the 2.5/3.0/3.5 v6 family from the Contour/Taurus, Cougar or Mazda 6s. They are all front wheel drive and would need work to convert them but they start at about 200 hp.
The perfect engine for a Pinto is a supercharged AJ 8 out of a Jaguar(4.2 400 hp). If you look at a side view of the oil pan area you will see that it looks designed to go over a crossmember in the same place as a Pinto's. The last Thunderbirds and the Lincoln LS have a normally aspirated version(3.9 290 hp), the Land Rover had a 4.4 version in both NA(300hp)and supercharged(450hp), though the oil pan would have to be changed.
Another engine would be the 3.4 v8 out of the late 90s SHO. It is an aluminum engine of about 235 hp and has the same bell housing pattern as all the Duratec v6s(thus the same problem of converting to rear wheel drive). You would have to fabricate an oil pan as well.
I have chosen to use a Rover V8(4.0 190 hp 250 ft lbs TORQUE)because it weights almost exactly what the 2.3 four weights(315 lbs)and puts out twice the hp and three times the torque in a very similar rev range! Rover was owned by Ford when the engine was made(technically making it a Ford engine)and I have both a 3.9(with a distributor)and a 4.0(wasted fire). You can also find 4.6 versions(or strokers to 5.0). Any of these can be stroked, cammed, tuned and ported to the 300+hp level and still be drivable in a very light car(Pintos are about the lightest at 2400 lbs), though it would have a NASTY idle. Not bad for an engine designed in 1958.
Grumpy 8)
79 Pinto Hatch, Yellow w/White Pony stripes, Pony wheels, 6650 miles
What kind of oil pan does it have ? If it's a rear sump you have problem. Even if it's as front you might have clearance issues.
vintageracer
I am considering the installation of an Explorer 4.0 V6 in a 79 4 Speed Cruisin Wagon.  It appears to me that the cross member will accept the 4.0 V6 and could be a bolt in with the proper motor mounts.  This "swap" would provide a 200 HP motor in stock condition with Fuel Injection and nice packaging for the accessories.
Of course there are other upgrades to consider such as rear-end and brakes however for this thread I would like to ask about the 4.0 upgrade.
This is my first post and I look forward to any replies!
