Rear Bumper
Date: 07/26/2021 01:08 pm
Date: 11/05/2016 09:03 pm
1977 Pinto for parts
Date: 10/10/2018 06:25 pm
1971-74 Various Pinto Parts
Date: 01/18/2020 03:44 pm
Date: 02/21/2022 11:11 pm
turbo 4 cyl and aod trans
Date: 12/14/2019 04:55 pm
74 & Up Parts
Date: 01/20/2021 03:22 pm
Bumpers
Date: 07/06/2018 04:47 pm
FREE PARTS!!
Date: 01/10/2017 02:38 pm
  • Online today: 152
  • Guests: 133
  • Total: 133
1978 power steering delete
Started by nicholas d. poulson, June 21, 2012, 07:10:26 AM
A manual rack has a smaller diameter splined shaft than a power rack but if you check Ebay there is a spline adapter for about 20 bucks that slips on the manual rack so you can bolt your coupler right on it. I cant find one at the moment but they exist because I bought one less than a year ago.
You will need manual rack tie rod ends since they differ from power & watch the spacing between the mounts on the rack. Some aftermarket racks are wider between mounting holes. It's an easy swap just watch the little details.
What you need to do is get a few parts: manual steering rack & pinion, manual steering alternator bracket, and different steering coupler for the manual steering. Once you have all the parts go to town & remove all the old stuff & put on the new stuff. The alternator bracket is completely different for the manual steering car which is why you need to switch it & unless I was mistaken the same thing for the steering coupler at the bottom where the rag joint is. I believe I was once informed they are different.
nicholas d. poulson
Can anyone give me info on deleting the power steering on my 1978 pinto?  It has a 302 V8 and I would like to remove the power steering.    Thanks, Nicholas
