1976 Ford Pinto
Date: 07/16/2019 02:51 am
Date: 01/20/2018 07:51 pm
MISC PINTO PARTS
Date: 08/27/2017 10:23 am
Date: 11/04/2018 02:34 am
Need 72 pinto parts!
Date: 06/14/2019 01:40 pm
Date: 02/05/2017 09:45 am
Windshield
Date: 01/15/2022 09:31 pm
Two 1978 Pinto Station Wagons
Date: 05/18/2025 03:10 pm
78 wagon instrument y
Date: 04/30/2018 07:41 pm
  • Online today: 1,090
  • Guests: 131
  • Total: 131
Lesson learned
Started by D.R.Ball, June 09, 2012, 10:25:58 PM
You can also rebuild your own parts, if the starter Bendix drive is not bad or the alternator is stator is not bad and even the bearings in both can be changed. Haynes has a book that shows how to do most of the rebuilding process in detail.
lugnut
I agree about the crap re-build starters & alternators auto parts stores sell these days.  Lately I have been taking my parts to a local rebuilder who repairs my old unit like new, and its actually cheaper than a 'reman' from the store and guaranteed for 2 years.  None of the ones they repaired have failed yet.
Lesson learned, when troubleshooting  an intermittent fault in the starter circuit ensure that the starter is bolted on tight. I had changed the starter solenoid once and was getting ready to change the starter switch in the steering column when as I was turning the car over with the key I heard a bump,as if the starter was loose so I got the car on jacks and sure enough the bolts had backed out causing the problem. So in the future when checking an electrical problem like the starter ensure EVERYTHING is tight not just the easy stuff (battery cables etc).The trouble shooting guide is great but I do not think this is in there.One more thing if you have Motorcraft parts keep them, the stuff made in China had cause the starter Bendix drive to continue spinning of which is not a good thing.
