MISC PINTO PARTS
Date: 08/27/2017 10:23 am
1980 Pinto Wagon
Date: 02/29/2020 07:01 pm
Date: 02/04/2018 08:26 am
1977 Pinto Hatchback Parts
Date: 08/29/2020 05:31 pm
Need Brakes for 1971 Pinto
Date: 04/27/2018 11:48 pm
2 Pinto Wagons for Sale
Date: 10/29/2018 02:02 pm
1976 Squire wagon
Date: 09/12/2018 10:30 pm
Date: 09/06/2020 01:57 am
Hood Hinge rubber boots
Date: 09/28/2018 05:49 pm
  • Online today: 782
  • Guests: 703
  • Total: 703
TURBO PINTO RUNNING!!!!!
Started by HiPopinto, May 03, 2012, 11:26:15 AM
im running 355s with a 28" tire and like  it ....
HiPopinto
OK I took a half hour yesterday to mess with the pinto!
I put the 150 jets fromthe 5.0 kit in the system
Lets just say THIS 2.3 DOES NOT LIKE that massive amount of Juice!!!!
80 jets going back in TODAY
Under load it was very violent!
I figure if I am going to break this it should be In October so I have all winter to get it back!
It is a real blast on the street, these turbos are different from anything I have ever had.
It has a .82 AR turbo so the boost is only on at 3-5k rpm, it actually drives like a 2.3 pinto!
Touch the NOS and it is a totally different car instant power from NOS plus BOOST!
I am a little torn on gears I have 3.50 in the rear and am thinking about what I should try in the rear or leave it be?
Any thoughts?
Dave
JohnW
Nice, I'll have to look into those when I go to buy one then.
HiPopinto
radiator is perfect hood closes no problems!
JohnW
That engine bay looks really clean, especially for an EFI turbo motor. I was going to ask about the radiator but I see you've already said it was for a 65 Mustang 289. How well does it fit height-wise?
HiPopinto
ok moveed timing out to 10 its surely stronger I originally had it at 8 due to the NOS
I have a MSD BTM mounted on the dash I turned it up to 2 (making it exactly the same under boost) retards it 2 degrees
I slowly worked back down to 0 on the BTM meaning its at 10 under boost and NOS all seems fine!
I just got a nice set of fomoco 3.89 gears and another c7AW case putting 3.89 ring under it next 3.50 are great with the OD but the 3.89 should be quicker out of the hole!!!
As soon as my center caps arrive I will wax it and take pictures for you guys
I will probably be planting my garden this weekend weather permitting so it may be a week more
Thanks for all of the positive comments
Dave
fast64ranchero
Very nice setup, looks nice and clean!
72 old V-8 parts Pinto
73 pinto, the nice one...
fast64ranchero
8 degrees would be a good spot to start, keep your total timing @ 20 at the max torque/rpm, I don't run the stock ECU so I'm not sure how much control you have of timing, but the timing should come down to whatever rpm you get max boost then start working back higher. prob makes no sense.
HiPopinto
I am going to play with the timig tomorrow if the weather is nice!
I am also seriously thinking about taller gears I have 3.50 in there now leaning to 3.89 or 4.11 3.89 seems as it may be a great all around gear
It should be a blast
Future plans involve a volvo b234f converted head on my other engine
Thanks
Dave
Very clean looking install! I bet that car will be loads of fun. Enjoy!
HiPopinto
I do not know the make or model of the intercooler
It came used off of ebay off a Japanese Go fast that was wrecked
I just measured it and it fit the hole
Dave
racer99
You will love the nitrous.
We had a 50 shot on a 2.3T and it was
worth 107 and almost 130 lbs ft.
your installation loooks real good.  I have a question though,  you said.....
"..... a Spearco intercooler cools all the hot air down!..."
I am very interested in where (and from whom) you got the SPEARCO intercooler.  Please let me know here on the site or via personal message.  Thanks
HiPopinto
Thanks guys!
I had to cut the upper intake down by .750 inch to make the hood close!
I gutted, ported, polished,  and rotaed it 90 to the front, a Spearco intercooler cools all the hot air down!
I will get some more pictures up in the next few days want to wash and wax her before I show all angles!
I currently have the timing at 8 degrees  I was little affraid of the NOS but I have a MSD BTM mounted in the cockpit so I can retard it on the fly if I need to!
Is 11-12  too aggressive with a turbo? Remember I am new to this!
10 is the factory setting but I can retard on the fly so I can play with it.
There is a bunch that went itno this it was pretty straight forward but it took a ton of time!
The rear is a 9 inch from a 65 mustang it is a perfect bolt in I did upgrade 5 lugs on all fours, 11 inch disc brakes on all corners.
Suspension is fully rebuilt with energy suspension poly both front and rear.
Radiator is an all aluminum 65 Mustang 289 piece.
If you have any questions or comments let me know.
I will be posting much more to come.
Dave
Svtcobra97
Congratulations!  I hope that my project comes out as nice.  Please keep the group posted on your updates.
johnbigman2011
I'll second that for sure. Clean install for sure.
racer99
HiPopinto
sorry
HiPopinto
Another view
HiPopinto
Hey all
After several years of work my 1980 Turbo pinto is going!
And man is it strong!!
1986 Mustang SVO Engine stock rebuild, Turbo Joe wiring harness, PE computer Stinger header full 3 inch mandrel bent exhaust .82 AR turbo and a 5.0 Nitrous Kit!!!
In the rear we have a 9 inch posi 3.50 ring and South side machine lift bars modified to fit the pinto from a Mustang II
This project has been really fun
I can't wait to take it to the track and test it out
Paint will come in the fall, and probably a c4 and 4.11 ring
Thanks
