1980 hood needed
Date: 04/23/2020 10:41 pm
Two 1978 Pinto Station Wagons
Date: 05/18/2025 03:10 pm
Drip rail chrome
Date: 01/14/2017 09:18 am
Crane Cam
Date: 02/26/2018 07:50 am
Date: 06/19/2018 03:58 pm
1978 Pinto Wagon V8
Date: 04/28/2023 03:26 pm
Offenhauser 6114 dp
Date: 09/12/2017 10:26 pm
Date: 12/10/2017 01:14 pm
  • Online today: 1,044
  • Guests: 66
  • Total: 66
Cut-out in driver side inner fender well
Started by Yelby, April 26, 2012, 09:22:55 AM
bbobcat75
its there to adjust or take apart the front suspion on the driver side, pass side has more room thats why there is no one there.
hope this helps
eric
1975 mercury bobcat 2.8 auto
289Wagon
 This is what I've been able to find out (for what's it worth)  Ford calls it a PLATE (front fender apron access hole cover) and that's it ! Not much help there with that. The parts book shows :
1973 as 2 required -I can't go lower then '73 but they have a '71 part # - also they are shown as a triangle shape.
1974 and then '75 up show only one required - but with different part #s
My quess is they don't even know why they are there !
I'll just put mine in there and if I should ever have to remove it - I'll know why it's there  :)
RSM
This has been discussed several times before. Got several different answers.....
Yelby
What purpose does the cutout in the driver side inner fender well serve?
It is located under the master cylinder and has a large rubber plug that closes it.
I don't think I used the hole to gain access to loosen any nuts/bolts when gutting out the engine compartment and removing the entire front suspension.
I'm considering fabbing a metal piece to close this for good.
