74 hood
Date: 07/03/2017 03:46 pm
Clutch Cable Needed
Date: 04/03/2017 11:03 pm
Wanted 73 pinto squire wagon
Date: 05/09/2020 11:59 am
Brake rotors
Date: 03/24/2017 09:02 pm
Front grill for '72
Date: 03/02/2022 12:09 pm
Pinto Parts for sale
Date: 06/19/2017 02:01 pm
79 pinto driveshaft
Date: 08/18/2018 02:03 pm
Wheels and Parts
Date: 07/06/2018 04:50 pm
2.3 turbo intake (lower)
Date: 07/15/2020 09:29 pm
  • Online today: 1,044
  • Guests: 987
  • Total: 987
coil spring install 79 pinto sedan
Started by zappid, April 20, 2012, 10:18:53 AM
lowtruk
I would rather have a Ford Emblem shoved in my eye that to drive a Chevy
I bought a spring compressor tool from NAPA. Way safer than letting a spring loose !
Installing my new ones this aft.
lowtruk
that is prety much it... you also need to loosen the sway bar end links if you have a sway bar to allow arm to drop all the way. I sugest putting a blanket over the spring so if it pops out it will not fly and damage something...DONT stand in front of it. I think the 79 is like earlier ones with a spring and a shock running throught the center and not a actual strut? if is had a strut it will not fly out. if it is a spring with a shock that comes loose first, the spring can fly out.
zappid
Just curious if anyone has experience with a coil spring replacement for a 79 sedan... My old repair manual says you have to remove the lower control arm by disconnecting at the strut and then at the frame, then slowly drop the arm with a jack...  Has anyone been able to do this an easier way?  The nuts under the lower control arm are pretty rusty and don't see to want to come off...
Thanks again for all the help!
