NOS Sedan decklid
Date: 10/23/2019 11:51 am
Date: 04/30/2023 04:31 pm
1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
Date: 05/03/2024 05:37 am
Date: 07/01/2019 12:23 pm
Date: 04/15/2017 05:14 pm
Date: 11/11/2019 04:49 pm
Date: 12/20/2016 10:47 pm
nos core support
Date: 01/03/2020 09:39 pm
  • Online today: 1,044
  • Guests: 942
  • Total: 942
coil spring install 79 pinto sedan
Started by zappid, April 20, 2012, 10:18:53 AM
jwpauto
So we ended up using external spring compressors and binding the springs with ratchet straps. Had a heavy guy stand on the crossmember while we jacked up the car, secured the spindle and cut the binds.
This is a very sketchy way of doing it, but the spring compressors simply could not compress the spring enough to be installed.
Everything else pretty much went right together. Now both front and rear have upgraded brakes and 5x4 1/2 wheels.
The ride height is even right now front and rear, but you can see the springs are slightly bowed due to the spring rate. We'll see how it settles with the weight of the motor, we can remove and cut the springs again if necessary and the rear ride height can be set with the air shocks.
Same size / length as OEM will have your front end sitting too high, with a 302w.
I set the spring on the floor. Used a square & marked a line up the coils, then cut them down to 3 3/4" less than 6 full coils (circles).
You may need to go even less..... so do not torque the ball joint, as you may well have to remove the coil to cut more off.
Use a zip blade, NOT A TORCH !
jwpauto
I used the same M2 coils, have them cut to same size as stock springs that came out. I have replaced all the bushings and ball joints. As you can probably seem I'm doggone up the finish on the coils trying every which way to get them in...
My notes show the springs as M2 with 302w & A/C.
I cut them down to 3 & 3/4" short of 6 full coils.
With my B2 engine, which weighs more than a 302w, it looks like the ride height may be OK (still do not have the car done). It will settle over time as well.
My headers will add weight , over say exhaust manifolds, of light weight ones made for a 302w.
Mine have 2" 18ga tubes to 3 1/2" collectors .
I had forgotten about this topic....
I ended up putting the springs back in after the engine was in place. Jack up the lower arm & bolt lower spindle arm (ball joint).
Final measurement of springs in shop... will up-date later.
If you have yours all apart, best time to install all new bushings , ball joints & tie rod ends.
If installing an engine so you can jack it up is a pain, have a couple fat buddies stand in place of it  ;D
jwpauto
I'm completely stuck trying to get mine back together. I have a '73, I got the springs out by removing the spindle and completely lowering the lower control arm. The spring did not 'just drop out'. It took a little bit of love with a bar and it popped out. I bought stiffer Mustang II springs and had them cut down to the same size as the stock springs.
I tried using the spring compressor with 4 arms on the inside, but the bar does not stay straight enough to go back up through the upper shock mount hole. Using the tool feels rather dangerous as well. I even tried disassembling the tool and inserting the rod down through the access panel and top shock hole, then put the threaded end back on the bottom and tried compressing it up into the spring perch. After I started to get it compressed about an inch or 2, the tool began slipping and rotating on the spring. This did not feel safe.
I tried using the compression tool that goes on the outside of the spring and even though it won't clear the upper spring perch or lower control arm when fully compressed, I tried compressing the spring just enough to get it to clear the seat on the lower control arm. Once I got it on there I tried jacking up the arm under it, but with no motor or trans in the vehicle, the vehicle raised, rather than compressing the spring up into the upper seat.
I don't know of any shops around Cleveland that will compress and band the springs due to liabilities with that. Any suggestions?
ghost.....maybe not that much shipping, but it would more than double the price of the springs. Has on most of the new parts I've had sent up from the States.
82expghost
wow 300 for shipping? sry to hear that, good luck with the build
98 taurtus, now in heaven
77 pinto, weekend warrior
92 grand marquis, daily
I called Standens & we talked about what I'm doing with this project.
Decided to cut one coil off & install in the other side. All clearances looked good.
So I cut the other one as well.
Lowered the car onto the floor & stood on the rad support & jumped/bounced & the car (springs) acted like all will be perfect.
Will not know till the engine (etc) is all back in & test drive it.
No idea when that will happen.....lots of stuff to do before that will happen.
Will up-date at that time.
Quotelandrum springs
With shipping from the States they would end up $400 - $500 for a set.
82expghost
in the future if you ever want different better springs, give landrum springs a call, the techs up there race mini stocks, they will set you up with perfect springs for 100 bucks that fit with no cutting required, any spring rate you want practically
Yes, fits up inside perfect. Measures the same as what came out & measures the same as a stock 72 spring.
No reply from Standens yet.
Pangra74
Did that spring even fit into the upper recess? Doesn't look like it from the pic.
joe
1974 Orange Runabout
I got one side in. But I think the 8 coils are too much. They will need to be cut down to the 7 coils like the originals.
I sent these pictures to Standens asking their thoughts on this.
You can see the spring outward bulge makes it ride against the inside of the spring.
The spring also is up against the upper arm.
I know this is not my topic, but thought it a good place to post the pictures and my problems.
If not, let me know & I'll start another topic for this.
Pangra74
I hadn't read the entire thread. I guess if those are V8 springs they could be longer. Good to know when I do the V8 in my wagon.
I've always hated working with springs, even small ones. They're just a pain in the butt!!
Joe
Looks to me mine would work the same, except for the extra coil I have.
I'll use a center compressor just the same. The B2 engine is a heavy beast & I need the ground clearance.
If it ends up too high, I can always cut the spring some later.
Pangra74
I've never had to use as spring compressor on my 74, and I've had them out twice. You just remove the spindle and struts and swing the lower arm all the way down and the spring just pops off the little lip on the lower control arm. Should be the same as my 74. getting it back in, I just use a long bar to get the spring back on the lip and jack the arm back up into place. See pics.
Joe
zappid
So, it sounds like you can remove the old ones with the Macpherson compressor and you need to put the new ones in with the single, inner compressor?  Sorry, I guess I'm pretty confused...   I'd remove the lower control arm, but those bolts holding the strut are so rusted I'd rather try to skip the headache.  Thanks again for everyones help!
spyville
I just removed them from a 76 and the spring compressor fit in just one way. Notice the shaft of the tool comes out between the upper control arm and the control arm mount.
Proud Owner of the hardest working couch in America.
My new ones measure up the same as the blue 72 except they have one more coil.
Reason for one more coil is the V8 in a Mustang ll.
I'll take measurements of the arms to see if something was changed.....
OhSix9
reeves.
Are you sure you have the right springs. 82exp had the instructions right. there is almost no preload on the springs and i have never needed a spring compressor. they did change the suspension in 73 your 72 may be different
Virgil to Sid
Newer cars differ from my 72 ?
I just went out & held the spring in place. Lower arm is down as far as it will go. Still nearly 3 coils past the spring seat. (stock spring is one coil less than my new ones)
I have ordered the through the center spring compressor. Supposed to be in on Monday aft.
82expghost
i just jacked mine up by the arm, put a jack stand under the bumper suport, loosen the bottom ball joint nut, not all the way off. unbolt the shock and take it out. next hit the side of the nuckle at the bottom, not the joint, and the arm should come loose from the nuckle, then lower the jack after you take the nut off the ball joint. Also it does make it easier to unbolt the strut bar, after you lower the jack all the way down the spring will barley be in there, now stand on the lower arm and the spring should just fall out. then i did it in backwards order when i put my new springs in.
If an auto store tells you the McPhearson (spelling ?) strut (outside of springs) will work to put springs into a Pinto, tell them they are full of BS !
Will not work.
I now have two types of these tools and they will not work.
You need the inside type spring compressors.
Spent huge money to find out.
I had my springs powder coated (they came like that, but semi gloss) & I now have one so barked up it needs re-coating.
Learn form my mistakes !
My springs (and I think stock springs) are too long to do like truk says. Plus if you compress them like that you be compressing them at an angle (ie: inside first) which can make them bow to the outside. Lots of engery there & you do not want them to pop out !
Without my engine etc in my car I wouldn't be able to jack the car up anyway.
In the past I had them squished and banded. I do not remember if it was 2 or 4 metal bands ?
I then put them in place. Bolt all back to gether, including the shock.
Cut each band & the bands pulled out OK.
QuoteThe compressor I was trying to use just had one bolt down the middle
Back in the 70s I had made one like that. Worked better than the tool I bought !
lowtruk
the easiest way to get a stock spring back in place is seat the top where it needs to go, then the bottom will be just a tiny bit longer than the lower seat. . with a jack under the to cont arm ready , use a pry bar and push the bottom back carefuly. it should pop into the back of that seat. then jack it up. I dont recal, does the pinto have a bolt on metal cover on the out side of the the spring tower like a maverick or mustang? if so bolt in in first so spring can not pop out
I would rather have a Ford Emblem shoved in my eye that to drive a Chevy
zappid
Thanks for the response, Reeves.. The compressor I was trying to use just had one bolt down the middle and kept hitting the top of the control arm... I'll have to get something like that to get them out....
So after they are banded, would you just put them in place and cut the banding or is there a technique to it?  Sorry for all the questions, I've never done a suspension before.... Thanks again, though, I appreciate the info!
Quote from: zappid on April 20, 2012, 02:55:23 PM
Thank you for the help... Reeves, could you possibly tell me how you used the compressor?  I tried a few times, but it doesn't seem to have enough room to get it out and couldn't find any info on the internet about it...
Thanks again everyone for your help
This is the tool I used to take the short springs out. They are 5 coils. New ones are 8 coils. Do not get this tool. It worked to get the short coils out, but will not work to get the new ones in (just tried).
Stock 72 Pinto has 7 coils.
To see the difference in my coils: http://www.fordpinto.com/general-pinto-talk/72-front-springs/
I will be taking mine into town & have a shop compress and metal band them to install the new ones.
The strut is the metal bar that connects the lower arm to the frame.
zappid
