1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
72 PINTO WAGON
Date: 09/23/2018 06:16 pm
1974 Ford Pinto
Date: 10/16/2017 10:45 am
Mallory Unilight dist 2.0
Date: 10/25/2019 03:44 pm
Rare parts for sale
Date: 09/10/2018 08:38 am
Date: 12/30/2022 01:30 pm
Pinto Parts for sale
Date: 06/19/2017 02:01 pm
Early 2.0 engines
Date: 05/09/2018 12:45 pm
Date: 08/01/2023 06:53 pm
  • Online today: 2,399
  • Guests: 1546
  • Total: 1546
Blue 72
Started by Reeves1, April 15, 2012, 11:45:09 AM
robertwwithee
Please tell me your retired so I can look forward to putting that much work in my car.  It's fantastic!
Cowl to inner fender braces have to go on before all the POR 15 is applied.
POR 15 will be on under the brace areas & then weld spot welds.
After attached again, Por the rest of them & cowl.
I'll weld the supports back on tomorrow, after it's cured.
Welded about every 4" (at spot weld holes).
Feels good to finally get this stating back together !
Done early this week ..... LOL !
Got the cowl & cowl to inner fender braces blasted.
Lots to do yet !
Shouldn't have to worry about rust now..
After welding in the snorkel I applied a thick coat of POR 15 inside / outside of the snorkle, then used about 20 lbs air pressure to "push" it under the snorkel, from 2 sides.
Then.....
Two coats on what is the inside of car. Three coats inside of box / cowl. I'll top coat it between cowl / box & explain the installation later.
Finally got some done.
Cut the rust out of the box & heater snorkel.
All new metal welded in & smoothed out some.
I put POR 15 where the snorkel goes & will weld in after it dries. Just the spot welds.
I'll be putting more POR 15 around it after welded on & seam sealer when dry.
I will then give both side of the box a quick blast to "freshen" it up, then the POR double wash stuff....then spray 4-5 coats to both sides.
Then weld back in place. Hope to be done early next week - then start on the cowl.
QuoteYet when home......she can figure out things for me to do that eats away my shop time !
It's a conspiracy , I tell you !
Sounds routine to me, lol.. ;D ;D
Quote from: 74 PintoWagon on May 23, 2016, 10:01:48 PM
It's coming together good..
Even a small step forward, is still a step forward !
"Normal" years I am already back working away from home by now.
"Normal" years , all the small work things the wife can come up with , she can / will deal with.
Got it welded back in.
Was going to weld around the edge & decided not to. Couldn't see any benefit.
Finally getting rain = shop time.
Got some POR 15 on the support brace for the master cyl / steering / firewall. Also on the new lip for the box.
Wife is picking up some new tiny wire brush thingys for the dremil (sp ?) , so I can clean up the spot welds for welding it back in.
Yep done that before , just finished my rear right quarter panel , kind of half and half , drill out the spot welds at the bottom and along the wheel well and cut out the bent stuff, got it all welded in and primed , next is paint ,  but thumbs up to you saving that 72 , good year . 👍
Not really that bad.
I think it took an hour , or a bit more, to remove the cowl & box with the spot weld bit.
Another couple hours to blast - air compressor has a bad cyl, so have to let cool often (gotta re-build one day , and it's nearly new)
Going to take a bunch of time to put back together though !
And I thought changing a floor pan was work,  😳 ,
Between the "Honey Do" list & trying to get the white car going I'm not making headway. Much.
Got the box (under windshield cowl) blasted & ready for several small repairs.
After that I can make a mess with POR 15 & weld it back on.
I'll post a picture later....
Perfect description, lol..
Good ole "Honey Do List", lol.. ;D
Spring break !
Two new tanks of gas !
Time to get going again.....before things dry up & the "Honey Do List" comes out !  ;D
A dry tank, that had to $uck. :(
Back last fall I bought a new tank of gas for the mig. Wanted 2 because I knew places would be closed over the Xmas break..... ran one tank out......install the "new" tank on Jan 1st - empty ! They sold me a dry tank !
So, I rolled it out & sand blasted a number of areas / seams , so it will be ready for welding.
A classic for future museums. ;D
When I'm done I think it will easily exceed 50 years before needing any re-fresh......with proper care, maintenance and storage.
In Canada, with our short summers, it could last 1000 years  ;D
Looks good, should last a lifetime.
Perf / rust in the seat bolt down areas. Cut back left & back right out.
No way to get the rust out from behind the smaller seat support brackets......so off they came.
I cut .125 plate to replace the back corners, and .125 plate as new supports and welded in.
Strong, solid & never to rust again.
Not getting lots done....returned home worn out.....
I did some sand blasting the last couple days. Having trouble with the air line freezing off.
Not good with edit programs, so put tape on 3 spots with perf. Back left seat mount & right side, same place. No big deal. Had plans to strengthen the seat mount areas anyway.
Third spot is in the seam where your left heel would be, below the dimmer switch.
Blasted seams to be welded on the under sides. Top side done before mounting on the rotisserie.
Loving the rotisserie ! LOL !
Car is in my shop.
Back for a few weeks & will do lots more...... with breaks to re-assemble the white car.
Just awesome Reeves! Where is it now? I LOVE the trunk model too!
I have Rotisserie envy you know!
