windshield
Date: 04/14/2018 08:53 pm
Early Rare Small window hatch
Date: 08/16/2017 08:26 am
13" Style Steel Trim Rings
Date: 10/09/2020 10:35 pm
Date: 04/25/2017 12:17 pm
Wanted 71-73 Pinto grill
Date: 03/09/2019 10:45 pm
Date: 10/05/2017 02:26 pm
Pinto Runabout wanted
Date: 06/05/2018 04:42 pm
Date: 06/07/2018 01:45 am
sport steering wheeel
Date: 10/01/2020 10:58 pm
  • Online today: 2,399
  • Guests: 1419
  • Total: 1419
Blue 72
Started by Reeves1, April 15, 2012, 11:45:09 AM
Quote from: HOSS429 on March 05, 2020, 12:48:12 PM
my 73 pinto is cigarette lighter delete which i think is pretty neat ..
Picture ?
HOSS429
The irony, - that a radio delete plate was intended as a "hole filler" for those too cheap to buy an AM radio. And yet today they are seen as prized items selling for a pretty penny.
I only have one delete plate, that for my '63 Rambler American. I think I paid $2 for it at U-Pull Parts. And yet the irony here is I have an old, 70's era Kenwood KP-500 radio that fits perfectly in the intended opening. So, maybe the radio delete doesn't get used in this case.  Irony.  ;D
Bought a radio delete plate some time ago.
POR 15 coated & now painted , done yesterday.
I'm going to cut a pattern & take that to town as early as tomorrow & get prices on making my own.
Out of Aluminum.
Found more on ebay, but with shipping, exchange, taxes & duty it would cost me over $225.00 each !
The one pictured below cost me $15.00 !
Need to add pictures.
The first two cable delete steering columns done
Finished the third one yesterday
Found a place in Calgary that carries Eastwood paints & the ceramic coating for headers !
I marked out the fire wall to be cut out (again).
Trying to get the engine back far enough to get the rad behind the support......
On jack stands now.
Set an engine block with the Milodon pan bolted to it, into the engine bay.
Bolted an aluminum bell to it....which will not work with the fire wall mads I made.
Need the Quick Time bell number 6065 to work with a T-5.
See they went up in price......$749.00 to over 1k !
So I've advertised for a used one that is out of cert (2 years cert) because if I bought a new one, it will be out of cert before it's running anyway.
Will be modifying the fire wall again.
Lots of other small jobs to get done with lack of money anyway....
Which brings up another problem.
Duplicolor bought out Plastikote.
Already had parts painted with Plastikote. Now I cannot find any paints to match the black I had been using.
Bought about 8-10 cans of different paint, different makers & none are the same.
Have not decided what I'll do yet.
Wanted some Eastwood ceramic coat stuff for headers.....cannot get in Canada because there is no French on the label !
Yup , on a rotisserie.
I lowered it yesterday as well. Back tires are on the ground.
Looking good. Question, the car is obviously up in the air... but I can't see any visible means of support? Is it on a rotisserie?
Getting a start on getting it to roll easy....for the cage build.
Took the original diff & moved the spring perches inwards.
Wire wheeled all the parts & a quick sand blast, then cheap paint.
When done with the diff & springs, I'll be building a "trailer" for an old gas welder.
By comparison, I rather like that!  Well done!!!
Dwayne :)
Bought a different style front spoiler for this car.
Made by Spook, for the early cars.
Fiberglass & is in new condition !
Got a small job done. Rear spring mounts.
Took 4 (short) days to clean the shop so I can work on the cars !
No work till Jan 3rd. so I should get some much needed shop time in !
No work on the car this winter.
Been busy with work....which is a good thing. One stretch was 24 days in a row.
Not as much as I'm used to, but it's law now to not work long stretches. Even if one is OK with it.......
Good thing & rare, I'll be working through spring break: more money - but less time to work on stuff.
I'll be ordering parts this car will need down the road though !
I seem to remember that style..... not sure I've seen them though ? Maybe "back in the day" ?
I have a bunch of grinding (sanding disk) to do..... yet I'm having a hard time getting motivated.
Maybe today......
Lift bars were the rage back in the 60's.They were made from box tubing welded to the axle tubes and run forward to a cross member near the front spring eye. The early pro stock cars around 1964 all had such a set up. And boy did they work. When you droped the hammer on it, the tires would be driven down into the track as the body would rise up because for ever action there is an equal reaction. Had them on my 63 427 Ford Sedan. They would plant the rear tires so hard pictures would show the wheel rim almost hitting the track. They were known sadly, that the axles of the 60's would not last very long. We would paint a white line down the new axle and change it when the axle twisted 1/4 of a turn.
Ladder bars ?
Like on my white car ?
Still not sure what I'll do. This blue car will be (for me) , likely 99% street car.
For this reason I do not really want ladder bars or to float the diff.
Quote from: Tonycando on August 25, 2017, 08:39:36 AM
Absolutely agree,but it's the bell crank that gives them an advantage over the Traction Master.it is a re-invented wheel but wheels have got better over the years.
On a tighter budget I would. To hesitate to run the other product or even a good slapped bar.
Tony
If you really want traction then make you some lift bars that go from the rear end housing forward to the frame. They work really good.
Both front / rear valance on the car are badly damaged , so....... NOS ones !
;D
Tonycando
Quote from: dick1172762 on August 21, 2017, 05:55:04 PM
I can not see how the Caltracks are any better than the tried and proven Traction Master bars. Only difference is Caltrack;s bellcrank up front. And the Traction Master bars are half the price of the Caltracks. Look at a picture of both and you'll see where Caltracks came from. Looks like they were made by the same company.
Tony
Tonycando
Quote from: dick1172762 on August 19, 2017, 01:43:59 PM
The caltracs bars look like a lot of money for a bolt on item. You could go 4 link for the same $$. And never forget the Lakewood slapper bars. The Lakewood bars really do work if you get a set of real Lakewoods and not the crap from China. And they are adjustable for a straight launch where the Caltracs are not. Once you install the Caltracs, you'll have to go where the bars send you.
The Caltracks can have the amount of tension in the bars adjusted.
entropy
There's a street.....guy...near me who runs a Maverick with a CalTracs set up.  That thing hooks like crazy on the streets.  Um....of Mexico.....
1972 Hoonabout
SBF swap
-308 cid
-CNC ported Brodix heads
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
Lots to do before I decide on Caltracs or ?
Just started a new job & "extra" cash will not be available for a few months.
Other than some shop supplies, the bulk of the extra $ will go into the white car, which needs valve springs & rockers. Re-coat the Headers & buy front wheels & tires.
Tonycando
Dam Derrick you've been busy,mine is going slow now lack of enthusiasm and free cash. Lol. The Caltracs should work seeing as they are a proven product and by the way were a great company to deal with and would recommend them to anyone.
Tony
Diff will be narrowed - don't know when though.
Still undecided on what all to attach to it yet.
One thought is ladder bars. If I do that, float the diff.
Thought maybe Caltracks ?
Springs will likely be OEM leaf springs ?
Hope to hear how Tony's (in Calgary) works out. 1971 with 351C - split mono with Caltracks.
Also wheelie bars  ;D
As mentioned (?) I already have a big bearing diff housing.
Also a Detroit Locker , that has been fluted to reduce rotating mass.
Have not decided on gears yet.
Not sure on which trans I'll end up with.
I have a T-5 & a C-4. May end up with something stronger ?
It's easier posting on facebook since this site doesn't want to load using my aircard. I also can't access Photobucket using my aircard so I can't put up pix either.
The chassis is coming out great. I can't wait to see it with the springs & axle fitted.
I just can't seem to find time to touch my 72. Too many things keep getting in my way.
Rear pan mods done. Some grinding to do here & there.
One inner wheel well removed - ran out of zip blades, on a Sunday.....and long week end !
