Date: 08/08/2018 12:26 pm
Date: 12/09/2018 11:35 pm
73 Runabout
Date: 11/20/2017 03:19 pm
Date: 03/30/2021 12:29 pm
Looking for front seats
Date: 08/10/2021 09:54 pm
76 drivers fender
Date: 07/20/2018 08:24 pm
Built 2.0
Date: 10/07/2018 05:27 pm
Date: 07/10/2016 10:17 am
Looking for a 1980 windshield
Date: 07/30/2020 04:51 pm
  • Online today: 2,399
  • Guests: 1401
  • Total: 1401
Blue 72
Started by Reeves1, April 15, 2012, 11:45:09 AM
Nice job on the engine mount brackits , hope you used a very common engine mount in case you need one in the future , I know the mustang II mounts are gold now and worst since they have a left and a right , also noticed your mount bolt is too short , Guess working on aircraft I see details like that , we always have the shank of the bolt in shear and use washer to space the nut to the threads and not have any load on the threads , looking at the perfect work your doing it should be art that could be hung on the wall to be admired .
New mount came in & I bolted it in place.
I have looked things over a number of times & I have the rest of the mount figured out.....just have to make it !
Worked on the motor mounts.
I still have more welding to do after the engine comes out.
I also will be adding a small pipe that the bolt will go through& weld in
Welding is hard in tight areas. That will be corrected...
Motor center line to diff set up perfect. Had to off set the front of the engine 3/8" to the right , to get the proper alignment.
Car is level front to back & side to side.
Carb flange tilts back 3.5 degrees. Will be level when car is done.
Engine level as well.
Next will be the trans mount. Waiting on a new mount from Ford. Then I'll make the cross member.
After that ,I'll make custom Headers - cross overs.
found it , its made by snow white industries , this looks like it useing the damper you have , its a two grove pulley but you can machine one off , they say it is two inchs shorter , hope this will help some , later Blaine
Guess picking the right parts to make it work can be very trying ,  wish I had photos to share but long since gone after 45 years ,a couple of divorces and a house fire you lose memories and most of your mind , know I made it work , with the excellent job that your doing to make it perfect any info will help from the past ,, what I do remember that the best damper (at least for 71 to 73 ) was the thin one , three bolt with a flat pulley , the one I use was off a dealer installed A/C that was cast iron and three groves , machined off two of them , the water pump after the mods done to it made the edge almost touched the water inlet on the pump after the bearing and flange was pushed to almost touch the seal inside the pump ,(or see it at the weep hole one the side , somehow the belt lined up and the back of the alternator just missed the back of the block ,  the radiator support brackets I put on backwards so I could make spacers to move it forward to the max to save space , the fan was a flex one with it bolted straght to the pump , guess some one will see this post and have a pile of 302 pumps and covers to see what is shorter , their is some company that did make a real short pump and pulley set up , dont know if they are still around but will check and post if they are to save time and gray hair pulling , later and stay safe , Blaine
I use the Ford Racing short water pump & CVF Racing V pulleys meant for this system . Saves 1.5"
I had no choice on the B2 damper.
Next one will be a 302w & likely an after market damper.
Plus I'm moving the engine way back & should be able to get a radiator behind the rad support.
Going to custom make a set of Headers : That is why I put the two sets of Headman Headers up for trade.
This remonds me of my first V-8 pinto I done back in 72 , used a 289 , only thing bad it was to long and I did not want to cut the rad support , noticed you have the long damper and the one I used was short , and had three bolts , saved a inch there , then a fellow working for my dad should me a trick to shorten the water pump by pushing the bearing into the water pump two inchs or more after machineing the nose off the water pump housing , did everything to shorten the engine (had a machine shop ) and it worked , still used the stock hood latch , now I guess the ford exploer 5.0 timing cover and pump may do the same , on a Pinto engine swap every inch counts ,, been there ,
Drives me buggy when folks strip a car & send that roller to scrap. Just because they want it to roll.
Many parts can no longer be found.
Not sure what the name of these are - clip nuts ?
They are for the upper control arms. Clip into place & bolts go through the control arm - 1972.
Being on a tight budgit right now...looked up home made rust removal.
Mixed Vinegar & salt. Soaked 3-4 days & washed up.
Buffed on my bench grinder with wire wheel.
Self etch primer & paint = better & more rust proofed than what Ford did.
Motor isn't where it's going to be. The aluminum bell I have on has ribs & a raised area where the clutch fork goes & I cannot get it back far enough, till I get the new Quick Time Bell # 6065.
Right now it's about 1/4" above the rack. It will be going back another 1.5" to 2" yet.
Going to make my own Headers & sell the two sets of Headman Headers I have.
New rack from Flaming River.
I'd like to see a picture of the oil pan you're using with it in the car to see what kind of clearance there is. My MII pan in the '71 had maybe an inch? maybe?  in front of and above the rack. The '77 power steering rack is bigger so.....
Pan ? Explain more & I'll take pictures...
On the early headers the two back tubes go down beside the inner frame rail, the front two go under the crossmember.  The Hookers l have for the '77 have two tubes going out through the inner fender wells like the ones you have but the other tubes go inside of the frame rails not under the crossmember. I cut the inner fender wells and radiator support out, the cage is going to come through the firewall and l'm using a motor plate not frame motor mounts so that gives a lot more clearance. l'm moving the firewall as well so your pics are a big help! Can you get a picture of the pan in the car?
I can still move the engine back 1.5" to 2" . Where the T-5 shifter is right now.
Headers on the left is up against the rack & touches the cross member, due to being moved back so far. I had test fit them on the white car while the B2 was away getting built, and they fit OK.
I have more to cut out yet.
I wasn't going to do this much (and for the 2nd time) but due to being off work & no sight of when I'll return to work.......plus I want to try and get the radiator BEHIND the rad support.....or at least have more room for the electric fan(s) than the white car.
Engine is just put together from spare parts & not the one that will go in it. Not the Bell I'll be getting as well. The Quick Time bell I'll be using is over $700 now & would be out dated (SFI) before the car is on the road again.
The Milodon pan is 8 QT + the filter.
The back goes down sharply & allows for more room to go backwards.
Sounds like yours are the Hookers ? Back two tubes go through the inner fenders & down by the control arms....like the ones made for my B2 ?
Is the Milodon pan better than the MII? As far as moving the engine back? I think my early headers are Hedman, (for sale btw} 3 piece and 2 of the tubes went under the crossmember. But l have no doubt you can make anything you want!
I always use the 30925 Milodon pans: https://www.milodon.com/oil-pans/ford-oil-pans.php
I have (2) sets of the old school Headman Headers.
They are not going to work - tested today. As you know, the frame rails narrow as they go back.
I may make a custom set.....or look into the ones people have used - shorties put on backwards ?
I like the idea of making my own & know I can do it......
Are you using swap headers and a MII pan or custom made pieces? When l put the 5.0 in my '71 the pan and headers dictated how far back the engine could go. I did move the firewall back a few inches though. Glad you're on the mend!
Getting better fairly fast. Moving around helps.
Went to the shop, easy day planned......ya, right ! LOL
Re-cut the fire wall. I want to get the engine far enough back to put the radiator where it belongs.
Drop a 302w block in & a bell/ T-5 trans.
More cutting need in a couple small fire wall areas & the tunnel.
Today I'll put heads & intake / carb on so I can plan on what / where to cut. As well as a set of Headman Headers.
Feel for you. I have been on ladders trimming trees. I did something??? to my knee. Not obvious at first but developed over time. It has been nearly a month now and no better. I can walk OK, but move j u s t the wrong way and ouch! Hope you get better.
No idea how / why, blew my right knee out & cannot get out to the shop.
So things on hold for now....
More progress with the dash mods.
I didn't drill for the speedo yet. Want to get it first so I get the hole the right size.
I had some antique lights I decided to use in this car.
The upper small ones are red , for warning lights.
Lower ones are green & are for signal lights.
Need 5 gauges for what I want to install.
The panels will be sanded & painted a trim black.
Made another out of aluminum 0.050 thick.
Weight is 5.3 oz or 150 grams.
Quote from: 71pintoracer on March 05, 2020, 07:44:59 PM
That's what kept the cost down. A base '71 Pinto was $1919.00! 1600cc engine, no radio, no cigarette lighter lol my '71 Pintoracer had 3 options, 2.0 engine, auto trans, and AM radio. Drum brakes, rubber floor mat instead of carpet and no cigarette lighter! It had a little metal delete plate! I still have it!
Something in your post about no cig lighter triggered a memory.
Dug out my ash tray & sure enough, no lighter & it has that plug thingy in place !
Wittsend - BOSS 302 ones go for crazy money !
The OEM one I have cost me $15.00 ! LOL
I'll be making a heater delete plate as well.
Heater / defroster is required to pass a safety up here, so a small electric one will be made to fit under the dash.
Going to delete the OEM heater in this blue car.
I think in the 80's and upward the delete plate became a hot item because magazines would do articles on 60's drag cars. You know those cars with special aluminum front ends, aluminum bumpers, batteries in the trunk, gutted interiors etc.. It was at that point that the plate took on an important life of its own. That being if you had a radio delete plate (and possibly a heater delete plate too) then YOUR car was like these rare factory race cars!
I think 72DW's delete plate account runs in the same vain as my Rambler delete plate. That being the irony of it all.
Well, went to town yesterday & got some aluminum plate.
Then talked with a welder & he talked me out of using aluminum.
Oh well, $10.00 & will be used someplace else anyway.
I have some steel but it's thicker than I wanted. Just the same, I went ahead & built one.
OEM one weighs 288 grams / 10.2 OZ.
Mine weighs 416 grams / 14.7 OZ.
I'll blast & paint in a couple days. Was -20c this morning. Fits perfect.
Cost for mine will be less than $10.00 with paint !
72DutchWagon
I got the radio delete plate, Ford part number D4FZ-6204371-A, from nospartsltd.com last year. Price was/is $ 22.09, I think I paid something like $ 60.00 including shipping to the Netherlands. Luckily it went below the customs radar. Still a lot of money for a tin plate but hey, sounds better then $ 225.00, and it's the original item in the original box.
Isn't this a strange world in which a piece that is worth almost nothing gets lovingly pressed, painted and boxed, then sent out to be shelved, becomes obsolete in ten years, then remains shelved and collecting dust for another 30 years, and then is allowed to fulfill its humble purpose half way across the globe... Just the idea of getting this poor tin plate out in the sun and have it travel was part of the reason I bought it.
HOSS429
it`s my profile picture ..
