78 pinto wagon
Date: 06/04/2020 12:42 pm
71,72 Pinto Door Panels
Date: 06/17/2018 08:27 pm
Rally spoiler wanted
Date: 05/04/2017 01:32 pm
parts needed
Date: 02/20/2017 07:58 am
Clutch Fork
Date: 03/31/2018 09:12 pm
Beautiful 1980 Pinto
Date: 04/13/2020 11:53 am
Squire trim
Date: 03/28/2018 10:11 am
2.3 turbo intake (lower)
Date: 07/15/2020 09:29 pm
Looking for a few parts - TIA
Date: 02/19/2023 12:18 pm
  • Online today: 531
  • Guests: 154
  • Total: 154
Heating/air conditioning problem
Started by lesterwa58, March 18, 2012, 07:45:05 PM
RSM
Have you checked to make sure you have vacuum to the controls? It's possible the vacuum line isn't connected. I too have a 1980 squire like yours but I've removed everything and installed a V8 under the hood. I'm just trying to remember where the vacuum lines were routed. If you happen to need that control I have the one out of my car and I know it's in good working condition. The vacuum line should be connected to the intake manifold and go across the firewall to a one way check valve. From there it goes through the firewall to the control panel. Also at that point on the firewall it goes from the check valve to a vacuum canister. A leak anywhere in the system will stop the doors from working properly. I'd give all the vacuum lines a once over to make sure everything is ok.
lesterwa58
I have a 1980 Pinto Squire, with a 2300 4 cylinder engine and auto trans, equipped with air conditioning.  This appears to be a vacuum operated sysem.  My problem is that neither the air conditioning or the heater systems want to work.  What would be the most likely problem?  How can I trouble shoot?  If I need expert help is there a shop in the Seattle area that would be familiar with the Pinto systems.  If the proble is the control unit and I need to buy a unit that fits in the dash area, does anyone have one in good working condition, and if so what would be the asking price?  Any help/information would be appreciated.  It gets hot in the eastern Washington area and I sure would like a working air conditioning system.
Please respond to: lesterwa58@yahoo.com
