Date: 03/27/2017 10:07 pm
Date: 02/28/2018 09:33 am
1980 Ford Pinto For Sale
Date: 07/01/2018 03:21 pm
Date: 02/25/2017 08:45 pm
71-73 sway bar
Date: 06/12/2021 10:12 am
1979 Runabout Rear Panel
Date: 01/04/2020 02:03 pm
Windshield
Date: 01/15/2022 09:31 pm
Date: 11/11/2019 03:38 pm
Date: 04/15/2017 05:14 pm
  • Online today: 178
  • Guests: 82
  • Total: 82
Dura-Spark Trouble Shooting....2.3L
Started by falconwagon62, March 15, 2012, 09:04:38 PM
Four things come to mind...
One, is the star shaped "wheel", the reluctor, on the distributor shaft under the rotor.
Second is the magnetic pickup which senses when a point of the reluctor passes it, telling the coil "when to fire" a plug.
Third, is the ignition control module, which governs the whole duraspark system.
Fourth, worst case scenario, is the drive gear on the 2.3L distributors has been reported to sheer off the retaining pin that holds it in place on the distributor shaft, keeping the rotor rotating in sync with everything else. To check this I would disconnect the coil and pop off the distributor cap. Crank the motor and have someone look and see if the rotor turns.
The first three, as far as I know, are just part swapping to determine which could be bad.
falconwagon62
my 76 is NOT getting any fire...I have 12V at the coil....any tests easy to do, I have a VOM and know how to use it... Thanks in advance.....John
www.ovcfca.com
www.falconclub.com
