Date: 10/27/2018 03:30 pm
Oddsnends
Date: 12/20/2016 10:52 am
MISC PINTO PARTS
Date: 08/27/2017 10:23 am
Date: 08/05/2018 01:58 pm
Date: 08/24/2018 02:50 pm
72 Pinto parts
Date: 12/04/2018 09:56 pm
Date: 05/28/2017 03:20 pm
75 wagon need parts
Date: 05/28/2020 05:19 pm
76 drivers fender
Date: 07/20/2018 08:24 pm
  • Online today: 178
  • Guests: 128
  • Total: 128
Need Help Identifying Emissions Device
Started by Disco78, March 15, 2012, 12:31:44 AM
77pintocw
Hey Disco78:
Attached are two possible set ups for the vacuum lines for a 2.3L.  Hope one of them
is close enough to your engine that it will help you.  Your vacuum valve is part 9A995.
Click on the figure for a better picture.
Thanks,
77pintocw
1977, Pinto Cruising Wagon, White with Blue Graphics
Disco78
THANK YOU!
"Doc" was able to verify the part number (D7FZ9A995A) and direct me to a dealer where I was able to purchase the part.
If you could send me the vacuum line locations diagram, that would be great.
-One happy Pinto owner
77pintocw
Hey Disco78:
The item is a carburetor air cleaner vacuum control valve.  Depending on
your engine set up (and since you have a 2.3L) the part is either a
D5AZ9A995 (most likely) or a D7FZ9A995A.  Green Sales has one D5AZ9A995.
If you give them a call at 1-800-543-4959 and ask for "Doc" he can help you
with locating the item since he has a Pinto and knows a lot about them.  Also,
if you need a diagram showing the vacuum line locations let me know and I
can post that for you.
Thanks,
77pintocw
Disco78
I noticed on my 1978 automatic wagon (2.3L) this emissions device located on the side of the air cleaner has a broken vacuum nipple. The previous owner decided to plug the vacuum line opening with a screw.  >:(
Does any body know what this is called, what it does, or where to buy one? Attached are some photos of it.
