Date: 07/21/2017 11:49 am
73 rear hatchback glass
Date: 07/06/2017 11:33 am
Date: 12/04/2018 07:40 pm
1979 Pinto Rear Bumper
Date: 03/26/2021 03:26 pm
Date: 08/24/2018 02:50 pm
Date: 08/01/2018 01:17 pm
Date: 05/18/2020 10:22 pm
1977 pinto rear bumper
Date: 04/19/2021 11:57 am
Date: 07/13/2018 02:21 pm
  • Online today: 212
  • Guests: 100
  • Total: 100
200hp
Started by 82expghost, March 10, 2012, 12:27:36 AM
82expghost
i have my friend in handling by a long shot, unles i hit a bump, i feel like 100 extra hp should be easy, i just needed to know what things can be done to get the power gains without buying actual stroker kits or special heads, junkyard parts and good old machineing, also i figured i would convert to e85, for a 350 cfm holley, what size jets about should i go with, if i have the 2.5 botom end, 10 or 11-1 compression, and porting, its suposed to be 30% bigger jets, but i have no clue where to even start, what size jets go in a 350 on a simi stock 2.3?
98 taurtus, now in heaven
77 pinto, weekend warrior
92 grand marquis, daily
johnbigman2011
Beamer / Pinto....... Allot of german engineering to conquer. Not to say it can't be done.... Good Luck
racer99
E36 is the chassis designation.
M3 is the sport tuned,high hp version.
Nice BMW car,cruiser,handler,big brakes,etc.
Mini-stock can get to that level.  Not sure how streetable it is and it may need race gas.
http://www.circletrack.com/techarticles/general/ctrp_0504_23_stock_crate_engine_overview/viewall.html
They have several articles on building Lima based race engines.
http://www.circletrack.com/sch/02/esslinger/articles/index.html
What heck is a e36m3?
82expghost
i really want to keep it looking stock, i even welded the heat shield off of the original exhaust manifold and put it on my pacesetter header, im going the alumanim head route and even painting it blackish brown to simulate rust to hide the head, i want to know how mush to shave my block to raise combustion ratio with a stock ballenced knife edge 2.5 crank and rotating asembely, i have access to alot of nice machines to do my evil work, i just need to know what to do, i want to smash my buddys e36 m3 and then some, wieght to hp ratio says anything around 200 or more will smash him, that is my delima, 1977 pinto against a e36 m3 on coilovers, 9 wide rims, exhaust and intake, I NEED to kill his car
when I have asked this question in the past of my more knowledgeable Pinto friends the answer has always been the same...
Carb setup = 150HP max and lots of $$$$$/time/parts needed
want 200 HP? you need to go the turbo route
I'm not saying you can't get 200hp out of a carb'd setup just that if you want that kind of HP you really should consider the turbo route.
82expghost
all i need is 200hp, i have a header and a 350cfm 2bbl, with porting and boring how close can i get, my buddy has a m3 that i need to smash, i have handling over him, now i just need the power and keep it looking stock
