72 Pinto
Date: 03/07/2019 12:07 pm
2.8 radiator
Date: 10/25/2019 04:10 pm
Date: 02/27/2017 10:10 pm
Date: 02/18/2017 05:55 pm
Date: 01/28/2017 12:30 pm
Date: 07/17/2018 09:22 pm
71-73 Front Kick Panels
Date: 04/25/2021 07:24 pm
Date: 08/09/2018 07:49 am
Date: 03/17/2019 10:15 pm
  • Online today: 1,431
  • Guests: 416
  • Total: 416
spindles!!!!! HELP
Started by gerardo Tovar Sandoval, February 17, 2012, 01:36:13 AM
The short answer is no without fabrication. The MII (same as 74-80 Pinto) spindle is about 7/8" taller (between the ball joints) than the 71-72 spindle.  I suspect this would affect the geometry.  One concern is increased camber gain on bump.  However I seem to remember somebody here installing the MII spindle in a 73 without complaint.  Another problem is that the hole for the tie rod end is larger in the MII spindle than the 71-72 spindle.  The 73 has a unique rack which uses the larger tie rod end, so the referenced person did not have a problem with this.
Im rollin in my pinto forever
Mustang II spindles fits on 1971 pinto?¿?¿?
:o
