Date: 02/16/2019 10:46 am
Date: 03/27/2017 10:07 pm
1972 Pinto for sale
Date: 05/19/2021 12:41 am
Two 1978 Pinto Station Wagons
Date: 05/18/2025 03:10 pm
Pinto for sale
Date: 04/19/2017 10:15 am
Parts for 74 Squire Wagon
Date: 09/16/2019 07:35 pm
Wanted 1973 Ford right fender
Date: 06/03/2017 08:50 pm
FREE PARTS!!
Date: 01/10/2017 02:38 pm
Anyone scrapping a 1980
Date: 03/13/2020 08:46 pm
  • Online today: 586
  • Guests: 265
  • Total: 265
zoop thru turbo deal
Started by racer99, January 22, 2012, 07:46:46 AM
fast64ranchero
Turbopinto72, Have you tried increasing the Power valve ciruit in your current 650 BP? I ended up drilling the Power Valve circuit to 92 thousands if I remember right to get the secondary side to feed correctly, worked great, and i could still run a normal size secondary main jets.
I have yet to find a cure for the transition from vacuum to boost with a blow through set up, I just couldn't get rid of the huge rich spike durring transition.  i think i might still hold the record for a Ford inline 250 six (modified Ford iron head) @ 497 whp and 501 Ft lbs
Walt
72 old V-8 parts Pinto
73 pinto, the nice one...
johnbigman2011
Racer, if it works............. I would by a set up from you to run on my 72.  8)
racer99
A pic of the bt setup I am changing.
beaner
give this guy a call his name is eric very smart guy  http://www.horsepowerinnovations.com/
he did my carb
brad :)
racer99
I have a CSU bt 750 onmy 306 Turbo Zephyr.
C&S aerosol carbs work well also for a bt setup.
robert t
Glad you guys are here.Look forward to any and all info you are willing to share on turbos.Pictures are always a plus too.
I have done both the draw through and blow through setups on both a 2.0 and 2.3 ( 2.5) motors. In my opinion, the blow through works better ( on a pinto) for a few reasons. First reason is, on a pinto ( other than using a intake manifold like on the 79 turbo capri/mustang ) the carb will be sitting low ( that is lower than the intake manifold). This may cause a puddling condition in various areas. Also, as mentioned above you cant use an innercooler with a draw through ( because of the puddling condition and the fact that the gas would condense on the innercooler and fill it up). The VWs all have the carb at the highest point and everything goes down hill, which makes it work real well. However, a " real good " thing about a draw through is that your can use a Vacuum secondary carb which is ( in my opinion ) the best way to tune the secondary side. On the blow through you have to use a mechanical secondary, ( which in my opinion is a royal pain to tune). The issue here is when the secondary side opens up its about the same time boost comes up and with out the tuning ( al la vacuum ) you cant get the fuel to dial in at the correct time i.e. early or later than the secondary throttle blades open. On my 2.0 I am using a holley 650 double pumper and just installed a restrictor plate ( for the secondary side) because when all 4 throttle blades are wide open I get a condition when too much air is being forced into the combustion chamber and my motor just cant handle all that volume. Gas however is what I need ( and lots of it) So, I need about a 500 cfm double pumper ( btw, a 4 barrel carb and a 2 barrel carb is measured differently so a 500 cfm 2 barrel would not be the same as a 500 4 barrel ) but i digress. I would toss my current carb if I could find a vaccum 4 barrel that would work in a blow through deal ( and not spend thousands). So, anyway I hope you get the right combo working and please show us pictures. Let me know if I can be any help.
fast64ranchero
draw through works fine, it does make adding a aftercooler interesting, although with all the meth injection stuff out there now, you can get by without it...
they have been proven to work.
racer99
Curtis,I too have grown tired of the crap on
TF and only lurk there.
Maybe we can pick up the hot rodding side
of the Pinto here.
I am on turbopinto also as well as the YB and
turboforums.
I have already had people say the draw thru deal wont work
but after talking with the VW guys I am going to give it a go.
Going to start with a stock location deal and maybe try a front
mount(have a scavenge pump already)but that will mount the carb
between the radiator and valve cover.
We will see.
Skratch
Hi Chris, glad to see you here. Not a lot of true hot rodding going on, but a fairly informative site. I like the draw thru idea with the 2.3. It makes for a lot less headaches. Got tired of all the BS on TF, so I don't post there anymore. Pretty much just lurk on this site, turbopinto.com and TF. Good luck with the project.
Curtis-----AKA Turbo Toy
racer99
I am going a different route with a new Pinto I picked up yesterday.
Instead of a blow thru turbo setup I currently am running I have been
hanging out with the air cooled VW guys and am going to try a draw thru setup.
Sort of like Buddys Turbo Pinto but a 2.3 based deal instead of a 2.0.
A friend is making 512 hp out of a 2280 with a draw thru so we are going to give it a shot.
The car was a 2.8/auto/8in car and will eventually be a 2.3/C4 brake/8.8 car.
It will be a 85/15 strip/street deal and will post pics later.
Just glad to be here.  ;D
