Date: 11/08/2020 02:10 pm
Date: 06/05/2018 09:13 pm
75 wagon need parts
Date: 05/28/2020 05:19 pm
Date: 10/24/2018 07:35 am
v8 springs
Date: 05/07/2017 04:46 pm
Crane Cam
Date: 02/26/2018 07:50 am
pinto floor mats??
Date: 01/11/2017 07:27 am
Tire needed p185/80r13
Date: 12/31/2017 09:08 pm
Clutch pedal needed
Date: 01/11/2024 06:31 am
  • Online today: 600
  • Guests: 241
  • Total: 241
Filter/Sock in gas tank????
Started by pintovol, January 06, 2012, 07:45:49 PM
RSM
A new tank will solve the problem.
pintovol
Quote from: RSM on January 08, 2012, 11:34:25 AM
You could...the only problem with that is, if it sucked some of that crap up the pipe and plugged it...your kinda dead in the water. If your going to do that put a filter in the fuel line right at the tank. That way if it plugs you only have the tube going inside the tank to deal with. If your in a position where you have to drive the car now, you could get a sock and install it later but put the filter in the fuel line now.
I am going to put a bran new tank on it..so it wont have any crap in it to plug the tube
RSM
pintovol
pintovol
can i run it without the sock if i put on inline filter in fuel lenr somewhere before fuel pump
ToniJ1960
 Thats exactly what my 70 did once the sock was replaced I never had a problem.
That is exactly what it looks like. I changed them in both my 73 and the 78 with the same sock. You can get them from sscenterprises.com. Same part for the Mustang II and the Pinto.
RSM
It's like that...I just remember the actual shape...been years since I pulled one out of a Pinto
pintovol
RSM
That's possible. There is a fine mesh screen at the end of the pipe going into the tank. The only way to know for sure is to remove the sending unit and take a look. That will entail draining the tank but if you can get a good look at the interior of the tank you will know what your dealing with. Chances are the tank will need to be pulled and cleaned. Most any radiator shop will do that.
pintovol
The Pinto I have sat for years, I had carb rebuilt and put new fuel pump on and also new filter
I have run a tank of gas out with a can of Sea-foam.
Just tonight the car stalled died like it ran out of gas, but i have almost half tan.
Sat for a min  or two fired up and it ran good/normal for about 2 miles then same thing died sputter like out of gas.
fired up again ran about 2 miles again same thing again about 4 times before I got it home
so does the tank ahve a sock/filter in it? that maybe the seaform broke crap loose
