Date: 10/28/2018 08:45 am
Many Parts Listed Below
Date: 04/20/2018 11:15 am
1980 hood needed
Date: 04/23/2020 10:41 pm
Date: 10/24/2018 07:35 am
Clutch/brake pedal assemble
Date: 12/21/2017 11:26 am
Hood Hinge rubber boots
Date: 09/28/2018 05:49 pm
Date: 09/12/2018 04:07 pm
Date: 02/18/2017 04:47 pm
Date: 10/24/2019 01:45 pm
  • Online today: 560
  • Guests: 553
  • Total: 553
Brownie's 2.0 - What a sssslllluuugggg
Started by dave1987, December 15, 2011, 11:43:31 PM
fast64ranchero
Dave, after chasing the smoking issue on 2 of my 2000cc Pinto's, I'm going to say it's valve stem seals causing your smoking issues. I have a valve spring compressor you can use, it works on the 2000cc head, I'd also make sure you get a Fel-Pro head gasket, you said it has 90K miles, it will need cam bearings, and might need guides, both should atleast be checked.
Let me see what I can come up with, I have 6 cylinder heads, only 1 is stock, I'll look at the stock one, if the guides are ok, I have a set of new cam bearings, maybe we can put a head together for you, or freshen yours up.. You know where I live, and you have my number, if you want some help let me know.....
72 old V-8 parts Pinto
73 pinto, the nice one...
Hey Dave, do the compression test again and if all cyls are close you should be fine on the head gasket. Also check the oil for antifreeze. You radiator fluid level sounds fine to me, just covering the fins is where is should be.
my thought on the smoke and accel issues however may have root in this... I have been told there is a vaccum line from carb to auto trans with a valve involved in the system. If the valve is failing tranny fluid will get sucked into the carb and burned thru the combustion process and can cause smoke out the tailpipe. I'll admit I don't know much about this but believe the way to test for that is to remove the vaccum line at the tranny and if you see trans fluid leaking... that may be the problem.
Dave (flash041) is the one that told me about the trans issue and may be able to tell you more
http://www.fordpinto.com/profile/?u=7334
also... if you are not coming to a complete stop and accel is sluggish I wonder... is it not shifting down into 1st gear? and you are starting in 2nd? and when you come to a complete stop it does get back into 1st? also may be a clue to the above listed issue? maybe?
the choke/carb issue at startup just sounds like a choke setting or carb settings to me anyhow. With it running rich as you described it would leave soot out the tailpipe that can mark the pavement as you described, unburned fuel?
then there is the head and valve seats... they could also cause your smoke out the tailpipe. Since your car sat for some time before you got it and yes, at 90K+ a head rebuild may be in order.
as a "non-mechanic" and no expert on all mechanical issues by any measure thoes are some of my thoughts anyhow
NOTICE: This thread is partially linked to the following thread to help diagnose these issues:
http://www.fordpinto.com/parts-resources-here-is-where-you-can-find-this-or-that/where-to-get-2-0l-piston-rings/msg121047/#msg121047
So Brownie has been on the road for about a year now. She has had her ups and downs, lots of TLC and gone through the first transmission with bad clutches, a second transmission which went out due to crud in the cooler and torque converter, and now her original transmission is rebuilt and going strong!
Before getting her road worthy she got a valve adjustment and the valve cover gasket replaced. Points put back on and the old crane cam electronic ignition removed due to a bad shutter wheel (may be repaired soon).
Now that I drive her twice a week, I am noticing some performance things and eliminating possibilities contributing to her sluggish performance.
Here are some symptoms:
1) Very slow acceleration. She is slow to accelerating 80% of the time, usually when trying to accelerate after braking and not coming to a complete stop. However, when accelerating from a dead stop she accelerates decently.
2) Upon cold start, the engine acts like the choke is doing it's job until about 20-30 seconds after start-up it starts to "mis-fire" or sputter until I step on the pedal. Then it sputters a bit, then smooths out and idles smoothly.
3) When climbing even a slight hill/inclined road, it starts to smoke greyish white clouds. Not a little puff, but billows of smoke if I stay on the gas. After I get up the hill or incline it lessens, but after it starts to smoke it really never stops.
4) After driving for an hour and a half or so and coming to a complete stop, then going again, it starts to smoke almost all of the time. Not badly, but enough to make anything in the rear view seem hazy. With this comes even slower acceleration than before, and giving it any extra pressure to the throttle makes no difference, only more smoke.
5) The carb has been rebuilt twice, and I am not really suspecting it, but the tune of it probably has some part in the rich smell at times.
I am leaning towards a bad head gasket, and what aids in that assumption is that I checked the coolant level today for the first time since I parked her after my Sunday drive (when I noticed the smoke for the first time in awhile), and the coolant level HAS dropped about an inch, just barely covering the fins at the top of the inside of the radiator. The water pump and thermostat do not leak, and I replaced both gaskets before getting her running again.
If it is the head gasket, I have a few questions:
1) Is it normal for a motor that has been sitting a long time, but with low-ish mileage (91k true miles on the odometer), to develop head gasket issues?
2) I have run a few compression tests and they are giving results around 130-135 per cylinder. I cannot remember if any neighboring cylinders are lower than others though, need to do another test.
3) I would like to recondition the top end just to ensure it is done, but how can I get the valve springs closest to the cam towers to compress? The only compressor places have for sale or for rent around here are the fork type that push down on the spring with the fork fingers and against the valve stem.
A head set isn't to expensive ($39.99 before tax), and I am certain it needs new valve stem seals at the very least.
Is there something else that could be contributing to these issues that I am overlooking, or am I on the right track with the head gasket? Coolant loss is my biggest clue, but i don't smell coolant in the exhaust, however when it idles on my parents driveway it can leave a black mark on the driveway at the exhaust pipe with an oily patch in the middle. Lots of what I call "soot" though.
