71-73 sway bar
Date: 06/12/2021 10:12 am
77-78 front grill
Date: 04/07/2017 12:35 am
Date: 04/13/2017 04:56 am
Date: 09/05/2018 06:30 pm
1976 Ford Pinto
Date: 07/16/2019 02:51 am
Date: 02/18/2017 04:44 pm
1972 Pinto for sale
Date: 05/19/2021 12:41 am
door sills
Date: 03/14/2020 03:20 pm
pinto for sale
Date: 09/11/2016 09:47 pm
  • Total Topics: 16,268
  • Online today: 289
  • Guests: 215
  • Total: 215
V8Junkie's 73 wagon
Started by v8junkie, December 05, 2011, 07:51:41 PM
v8junkie
Sorry for the long response time...the carpet that came with the car was complete but worn so I took it to an interior shop and had a new piece custom made snaps and all. I couldn't find a premade anywhere when I was looking.
73 Pinto Wagon
64 Falcon Futura Convertible
Were you able to purchase that carpet pre-made for the car, or is it custom?  Someone was asking about rear carpet for wagons earlier this week.
Quote from: v8junkie on September 18, 2015, 08:55:08 PM
So many parts and so little time...seems like it's time or money...cant have both.
That is so true...
BTW, carpeting looks great..
v8junkie
Little overdue update on the wagon...looks like the ranchero/falcon 8" is actually just a bit narrower than the pintos stock rearend. whoda thunk?
The car actually came with a/c but i never knew until actually getting under the hood. I've always been so busy with the body and interior I haven't been that far until now. Now I have to decide when I do the swap if I keep the a/c or not...I'm leaning towards yes...but that means a lot of extra work getting everything to fit..the challenge is why everyone doesn't do it though right?
I got a used aod transmission for it so it'll cruise the freeway a little easier. Hopefully it wont need to be rebuilt right away...always a risk
Got all the stereo and carpeting purchased but haven't installed anything permanently because I've been so busy with other projects and I don't want to get started on something and have to stop and come back to "where did I leave off"
73 Pinto Wagon
v8junkie
Finally got the carpet for the cargo area of my wagon..not cheap but the quality is great!  :)
73 Pinto Wagon
v8junkie
Does anyone make a decent carpet kit for the rear of the wagons (cargo area)? or the rest of the wagon?  The cargo area of this wagon's carpet is worn out and the rest of the car has shag carpet that is too disco for me...lol. Thanks!
73 Pinto Wagon
v8junkie
Thanks for the input, I need to pull the panels anyhow to decide if I want to mini-tub this thing like I did my Camaro. I am glad to hear the sound is good from back there. I was thinking if speakers didnt go there I would have to run wire up to the headliner somehow and make a panel for the hatch. That just seems like it would be a wiring and sealing nightmare.
73 Pinto Wagon
old 1973
 You are correct on location ,I have a 73 squire I did not need to build custom rear panels ,there is an area just past rear wheel wells that will accept  6x9's  and that the rear seat operates as normal. I did however have to cut some sheet metal behind where I mounted them ,so the magnet and part of speaker would fit into the recess. It ended up a clean install and overall sound is good.,my next part will be front speakers.
My rides: 1972 Squire wagon (Kermit)#121
               1973 Squire wagon (Penny) #120
                1975 Mpg sedan (Pumpkin) # 122
                 1978 cruiser wagon (casper)
v8junkie
Question for the pinto owners out there... What/where have those of you who have done stereos in wagons found to be a good spot for speakers in the rear? I have no problem building door panels for the front to get what I need, but it seems I have to go all the way behind the wheelwell to install any speakers for rear fill. I am not sure I want to start building custom side panels for it because I want to keep the backseat functional while up and down.
73 Pinto Wagon
v8junkie
Put the alarm in today, Viper 350plus and SPAL door lock kit. It's the same alarm I used in my 68 and after installing it once the second time was even faster. I added keyless entry since I have no door locks anymore and also dome light supervision. I cant believe how 'virgin' this car is...it is really nice to work on a car that isnt full of stripped out bolts and wiring nightmares. I started on the stereo while i was doing alarm. Got pretty much all the stereo wiring done that requires disassemble of dash. Neighbors are already coming over when I have it out of the garage to check it out and tell me their Pinto stories... :)
73 Pinto Wagon
falconwagon62
Wagon is looking great!!!!
I have just started mine, 1976 Wagon....I did a 78 Crusing Wagon 2 years ago on here....and I am President of the Falcon Club, in the state of Ohio!!! and Co-hosts of the 2012 Falcon Nations....Pinto's and Falcon's....gotta be a personalty thing...lol
www.ovcfca.com
www.falconclub.com
v8junkie
I also wanted to note, the neon door handle mechanism works flawlessly with the pintos original door rods and the opening and shutting of the door is sooo easy. No special tricks or fancy fabrication needed there. I would tell anyone thinking about doing this that the neon handles are perfect for these doors.
The gas door/cap on the other hand works really well but may have been easier if taken from a car with driver side fuel door vs. the neons passenger side. I am nothing but happy with the way it came out though.
73 Pinto Wagon
v8junkie
I took the whole assembly off the neon, it has the filler neck and all. So it is using dodge neon fuel door, gas cap, and filler neck. In hindsight I would have probably took the quarter off a van or something that had the neck on the opposing side for ease. This fit really well though. Only area that needed to be reworked is where the filler neck and the body come together.
73 Pinto Wagon
Quote from: r4pinto on March 17, 2012, 06:28:32 PM
Looks really good. what kind of gas cap are you gonna use behind that fuel door?
That's an interesting question.  I just bought a new 2012 Lincoln MKT and it doesn't have a gas cap at all behind the fuel door. You just open the door, shove the nozzle in, and that's that!
v8junkie
A couple of better pictures since final paint...She is at the glass shop now getting all glass replaced or reinstalled. Wont be long before the transformation begins *evil grin*
73 Pinto Wagon
v8junkie
Not Pinto related but out of same garage...the rearend for my Camaro showed up! 33 spline Moser 12-bolt narrowed and set up for the 4-link for the 68...:D
73 Pinto Wagon
v8junkie
I have not got that far yet, the seats might be too big...I have a few cars though. They will go in something. after buying the book to figure out wiring and the cost of seats I am determined to use them in something...lol
73 Pinto Wagon
Scott Hamilton
Did you ever install the Lexus seats in the Wagon?
I'm thinking this is a real neat 'upgrade' and I'm interested in how this goes. I was never fond of the stock Pinto seat and looked into Fox Body seat replacements at one time- The Lexus seats seem very regal-
v8junkie
She is out of paint, some assembly required....next stop, glass shop! WooHoo!
73 Pinto Wagon
Scott Hamilton
How cool is this! Love the door handled and fuel door mods- really good stuff... Keep posting shots and keep us updated. You are really lucky to even have a body shop to work on your pinto... Last time I had any work done I had to go to the local ford dealer and that was like pulling teeth. No one wants or takes pride in their work these days- it's really nice to see stuff like this.
v8junkie
Picture of the interior I took while it was getting some of the rust around firewall worked on...
73 Pinto Wagon
id leave the paint as is, straight 6 it with a turbo along with steelies and dogdish caps and roll...
v8junkie
That is a bummer, I would love knowing as soon as I got my parts the car would be gone...
73 Pinto Wagon
man, i wish you were closer, id kill for the leftovers of the ranchero.....
v8junkie
Shot of the door handle being grafted in..I used rear doors off the neon and will be using keyless entry with the rear hatch as a backup. I did this because I do not want to have to use 2 keys and the handles look better w/o locks in them. Still deciding on mirrors. Most everything is in the pillar now and I am not sure I want to go to that extreme on this build...
73 Pinto Wagon
I like the idea of a flip-open fuel door on a Pinto!  No worries about losing it or having it stolen!
v8junkie
I know that once a car is painted you are supposed to move on to something, anything besides the body...but here we go again...I bought the rear doors and the rear quarter off a neon and am grafting them into the wagon. My paint guy is SO patient with me thankfully. Pics will be added as I go of course...and BIG thanks to Fred for the piece that goes between bumper and car! It got here safely and is worth every penny. :)
73 Pinto Wagon
I'm with Scott- that is a delicious color!  ;D
