Hatch needed
Date: 09/10/2017 09:16 pm
pinto parts for sale
Date: 07/25/2018 04:51 pm
Date: 12/26/2016 04:29 pm
Date: 06/24/2020 06:12 am
Date: 05/13/2021 05:33 pm
need 1978 pinto guage cluster
Date: 03/07/2021 07:35 am
Date: 10/25/2019 04:05 pm
front end parts
Date: 03/30/2018 12:48 pm
1976 Ford Pinto Pony
Date: 09/06/2018 05:40 pm
  • Online today: 1,044
  • Guests: 984
  • Total: 984
Battery tray protection?
Started by popbumper, November 14, 2011, 04:16:46 PM
Pinto1600
Mac's Antquie Auto in Lockport N.Y. has a small mat that goes under the battery,cut to fit. I use on both cars and the P/U. Works great!
Happiness is..Driving a classic Pinto
Use a plastic tray and paint the battery tray with por 15 and surrounding area if you like then top coat with paint.
I wonder... Has anyone tried spray on bedliner? couldn't hurt to give it a go.
I would use a gel cell battery like an Optima or comparable.  This will reduce the risk of damage from a leaky battery.  I have had one in my 67 Mustang for years and do not miss the acid damage in my perfectly detailed engine compartment.
lugnut
Eastwood used to sell an anti-corrosion treated pad to put under batteries that I have used in the past.
79/85 RX-7 have a real nice plastic tray under the battery.
PintoMan1
i myself used a rubber pad cut from a big truck mud flap
1973 pinto runabout
Having restored the engine compartment and installed a new battery, curious if anyone else has recommendations for a "pad" to place in the battery tray to keep the battery from direct contact with the tray. Does anyone else do this, and if so, what material did you use? Rubber pad? Closed cell foam? Anything else? Thanks.
