Pinto Watch
Date: 06/22/2019 07:16 pm
Intake manifolds
Date: 03/06/2021 03:04 pm
Date: 09/20/2018 11:01 pm
Date: 08/09/2018 11:09 am
Gas Tank Sending Unit
Date: 05/22/2018 02:17 pm
Date: 02/22/2017 01:58 pm
Date: 10/03/2018 10:46 pm
Date: 11/05/2020 06:32 pm
Radiator
Date: 05/27/2018 06:07 am
  • Online today: 614
  • Guests: 544
  • Total: 544
My new Pinto
Started by r4pinto, April 28, 2005, 02:59:46 PM
joeyg
Quote from: r4pinto on April 30, 2005, 09:48:47 PM
Guys thanx for all your support with the Pinto I'm getting. As of Saturday 5/7/05 it will be officially mine. A buddy I work with is helping me pick it up that day, so then I'll have a Pinto that's not meant for the junk yard.
Then I can start swapping out the parts I'm gonna use. YAY!!!!
I started to primer the rear quarter after grinding off some surface rust & chipped paint. the other shot is my cowl repair. it had chipped paint & surface rust.
my modded mustang II console. Not perfect, but I like it. Not to mention a cup holder I installed in the console bin.
more pix. Look at that nice pcca sticker in the window.
core support before & after
Man, it has been a while since I have updated this post.  :hypno:
Anyways, I had worked on the car until it got too cold out around november, so it has sat in storage since then waiting for warm temperatures. As I previously stated I found bad brakes & got them fixed, even though I needed a brake rotor. Just got that so it's going on the car to get it stopping flawlessly. It has no air in the system, so it's got a glld solid pedal. Unfortunately I wasn't able to take it to Carlisle last year, but she will be there this year.
With some good help from Quickrick I was able to get more parts for my car so it will be safe. Rotor, radiator core support, & soon rear axle. I bought a leaf spring off him to replace the broken one I found around September last year & it handles pretty good. I had to replace the tires as they were shot so they're good now. The carb's shot, so I bought a rebuild kit & rebuilt the one from the parts car. I just gotta adjust it & replace the choke & all will be well. I got some nice interior parts for it & will be installing them probably tomorrow, as well as changing the tranny fluid & engine oil, so all will be fresh & safe.
More updates & pix coming soon. :fastcar:
Changed the master cylinder, but no dice... still no good pedal. I noticed the RF brake pads are worn more than the LF & the wheel cylinders leak.. I'm gonna be getting my parts car out of storage tomorrow so I can take off all the brakes, carb, & anything else I need off it.
Changed the pan gasket, and sure enough, no fluid... went ahead & put a new filter on the tranny, & accidentally overfilled it, so tomorrow I gotta drain about .5- 1 quart, but man, it shifts really good.... As I was driving it I figured the car has a bad master cylinder as I could pump up the brakes & get them to work.... More to come soon.
Picked up the car today... the doors are gonna need replaced, as is the rf fender, which I have a good one on my parts car... Other than that it's in good shape, body wise... started it up when I got it home after getting a little gas.. The tranny does not go into any gear, & I'm thinking it's possibly a lack of fluid.. Checked it with the car running & it didn't even register on the dip stick... Gonna change the filter & pan gasket tomorrow after work & see if it goes into gear.. If not, the tranny from my parts car will go in..I'll have pix posted soon.
Thanx.. I know what youre saying about learning on this one, as I've really learned alot about these cars from the green machine... All parts I bought for it will transfer to the 77 as well as the rally steering wheel, and the rear defrost circuit as well.. I figure I might as well personalize the 77 to make it mine.. I'm just looking forward to picking it up so I can get it ready to go to Carlisle in June..
Sad though... one back on the road, but another off the road at the same time. :-\
Farmboy
   Good for you R4, I'm sure this one will be a cakewalk, it seem's you learned alot from the green machine. Another Pinto back on the road, it seems to take 2 to make 1, at least in my case :)
74 Pinto Wagon
71 Runabout (parts car)
lol... no, but I did notify her next of kin...lol Atleast the tranny from it will be put to good use... Thanx on your comment on my replacement Pinto.. It should drive nicely once I drain the tranny fluid or change the tranny, whatever's needed.
Hey R4,
Did you have your Green Pinto's organ donor card filled out???? ;D
Nice Score on the Root Beer Pinto
From pintony
yeah, she is no more  :'(... Now, a moment of silence for the fallen.... May she live among the big Pinto dealer in the sky...  Atleast she will live on through my next Pinto.
I haven't decided what to call it yet...maybe the bronze bomb....
I'll letcha know once I get it driveable...lol
losin sux
nice find Matt.  So the Mean Green Machine is no more, you now have the (I think anyway that is a bronze)  Bronze Burly Bucket?
77 HB 2.3 C3 3.40
last... not bad for  $400 so I'm pleased so far... I'm gonna transfer the parts from the 78 onto the 77 so I'm still using what I had put into the 78... Hopefully she'll be ready for the Carlisle Ford show.
another
next
Well, after finding my pinto had severe rust damage I started to look around for it's replacement... That's when I found a 1977 Pinto sedan.. It's for $400 and needs some tranny work. The body's in good shape, less the driver door so I'm gweek from Saturday... Already got a buddy of mine to help with the towning of it... Here's a few pix of it...
