Date: 10/26/2020 03:24 pm
Date: 03/27/2017 10:07 pm
Looking for front seats
Date: 08/10/2021 09:54 pm
Date: 02/28/2018 09:37 am
1980 Ford AM radio
Date: 12/22/2019 11:57 am
1980 cruising wagon ralley
Date: 07/12/2019 01:41 pm
pinto floor mats??
Date: 01/11/2017 07:27 am
Date: 10/04/2019 08:43 pm
Date: 05/15/2022 11:36 am
  • Online today: 178
  • Guests: 95
  • Total: 95
excesive blow by
Started by Pup70, October 25, 2011, 07:55:03 PM
Mine ?
But then it wouldn't match the licence plate ! LOL !
RSM
Sucks to hear you have some internal problems there Pup70. That 2.3 w/turbo that Reeves is talking about would be a lot easier on the wallet and a time saver over installing a V8 like you were talking about. I really wish I had done that instead of the V8.
Where are you ?
I know a fellow in CA with a 2.3 turbo that will/may part with it. He had it built for a 76 Pinto & lost interest. Never ran the engine.
If I remember right, it also had a C-4 & 3k stall converter.
Pup70
that was ok but i bigger issues now the number 3 piston broke a piece of the op and bent a intake valve.  So if any one know a good machine shop near me let me know or i might sell it as is for the right price
On the block , the pcv has a hose that goes to it....BTW did you do any work to the top end IE valve job or replace the valve seals ?
RSM
The separator is below the intake manifold on the block. There is a hose that comes off of it and the pcv valve fits into that hose. It's unlikely thats the issue but it's worth taking a look at. A 79 wagon I bought about a year and a half ago had the same issue your having. I got to checking everything and found that someone must have had the engine apart for a while. The separator was full of junk...from what I have no idea. Once I removed it and cleaned it out it helped the problem but the main problem was that the engine was just worn out. Like I said before, a compression test can tell you a lot. Hope this helps.
Pup70
you had mentioned oil seperaotr what is that and were would it be located
RSM
ok...just curios on that one. Have you ran a compression test to see what you have? That might give you some indication as to whats going on.
Pup70
 I clocked them oppasite each other i have rebuilt engine before and know the proceeder that why this one has me stumped
RSM
I thought thats what I said...
I think RSM means the split in the rings, were they lined up or one at top, one bottom, one left, one right?
RSM
Let me ask you this...when you installed the pistons, were the rings all lined up to each other or did you space them around the piston?
Pup70
i have maybe 500 miles on it and it just started doing this a little while ago all the rings are new as well as the bearings i ridge cut the cylinder honed them ran a gauge to make sure they weren't ob longed gauged the rings.  Reassembled and all was good but now i have this problem and im one small step from dropping a V8 in then deal with this 2.3 any longer.
RSM
Have you checked to make sure the oil seperater isn't plugged up or anything. If the pcv system isnt working it will do what your talking about. Make sure you have vacuum to the pcv valve. If all of that is in good working order then you possibly have a ring issue. Did the engine just start doing this or has it done it from day 1?
How many miles on it now ?   Fred   :)
Pup70
I have 77 cruiser wagon with a 2.3 that i rebuilt with a mild cam and 80 thousandths of the head. it runs great but just has to much blow by to the point i get puddles in the air cleaner.  It has a new oil cap and pcv what else could cause this.
Thanx
