Pinto Vinyl Top
Date: 10/09/2020 10:29 pm
1978 RUNABOUT
Date: 04/01/2017 03:18 pm
Wanted 71-73 Pinto grill
Date: 03/09/2019 10:45 pm
Date: 09/15/2019 12:28 pm
Hoard of Pinto parts
Date: 12/17/2016 04:14 pm
Front Body parts needed
Date: 02/09/2018 06:09 pm
Date: 05/22/2018 01:54 pm
72 Pinto parts
Date: 11/14/2019 10:46 pm
72 PINTO WAGON
Date: 09/23/2018 06:16 pm
  • Online today: 148
  • Guests: 104
  • Total: 104
Super loose steering on my 74.
Started by sarahstubbs, October 25, 2011, 10:43:04 AM
78txpony
The joint on my 78 failed back in the early 90s - it was made of a plasticky compound.  I drilled out the rivets and cut a round disc from an old bald steel belted tire to bolt in.  It still looks and works great to this date.
The joint on my Olds came from the factory with - get this - a round steel belted rubber disc!  After cleaning it, it looks like brand new!
-Rob Young
1997 H-D Sportster
Jinxter
I've always used the Dorman parts in the HELP! section.  I can't remember offhand, but it's either #13000 or #13001 that fits.
one is universal, the other is Chryseler.  IIRC, it's the universal one you want.
Beat it to fit, paint it to match...
JohnW
http://www.fordpinto.com/pinto-faq/steering-discsteering-couplerrag-joint/
Here's some info on it.  I don't know of any parts stores that can look it up for you, but the Napa universal #630-1012 fits - I put one in my car.  They could not look it up by application nor could Parts Plus - and Ford told me a couple dealers in other states had old stock.  You need to pull the column and take the rivets off with a grinder, then bolt the new one in.  Not that bad of a job aside from reaching down to unbolt it - as long as you have access to a grinder.
Your car is currently being steered by only the safety bracket put around the joint slapping the steering box - don't drive it much til you fix this.
Sarahstubbs, this is what you are looking for...
sarahstubbs
PintoMan1
that's what i was thinking it was.  the rag joint
1973 pinto runabout
82expghost
i think your talking about the rag joint, it has a round disc make of what looks like heater hose material, it is like a u joint but its supossed to act as a vibration and bump asorber, you should be able to get a new one at any auto parts place
98 taurtus, now in heaven
77 pinto, weekend warrior
92 grand marquis, daily
sarahstubbs
at the end of the steering shaft, the u joint? im guessing. thanks so much
PintoMan1
are you talking about the steering shaft itself or the two mounting areas?
1973 pinto runabout
sarahstubbs
After pulling the steering rack to switch the starter i was able to see why my steering is so loose! there is absolutely nothing (im guessing it was rubber) where the steering assembly connects. 2 bolts 2 star. any ideas?
