Lower Alternator bracket
Date: 08/26/2017 05:11 pm
Rear brake shoes
Date: 01/23/2017 05:01 pm
1976 Ford Pinto
Date: 07/16/2019 02:51 am
Wheel cap
Date: 04/25/2022 11:21 pm
1971-1975 Pinto
Date: 01/09/2017 04:14 pm
Date: 07/20/2018 03:00 pm
1973 Interior parts wanted
Date: 01/02/2017 11:02 pm
Clutch Cable Needed
Date: 04/03/2017 10:54 pm
1971-73 2.0 motor moiunts
Date: 05/17/2024 09:18 pm
  • Online today: 169
  • Guests: 78
  • Total: 78
79 pinto wagon starter removal UGH!!!! Help!
Started by rick67, October 24, 2011, 09:08:20 PM
JohnW
Spray them with some PB Blaster first and let it soak.  I'm pretty sure I used a pipe on a 3/4" drive ratchet to get mine off.
78txpony
Use a good impact wrench on theose rack bolts - they are held on with like 100ft/lbs of torque + rust...
-Rob Young
1997 H-D Sportster
JohnW
Yep, just pull those 2 bolts.  I tried doing my starter in a driveway - wasn't going to happen.  Once the rack is out, you can use a long extension and have perfect access to all 3 bolts and the starter will come out straight towards the front.
flash041
no need to disconnect the powersteering line or tie rods. Those can stay connected and rack can just swing forward and down.
rick67
flash041
You need to unbolt the steering rack and pull it out of the way.
rick67
  Can anyone please help me with pics or a how to?  Just got a 79 pinto wagon barn find with 39000 miles and a 2.8 automatic.  The starter needs replaced, and I can't seem to find a way to get it out now that the bolts are removed?  Do I need to lift the entire engine?  Any help GREATLY appreciated... Everything in car is bone stock.
Thanx,
Rick
