2.3 bellhousing stick
Date: 07/24/2019 06:50 pm
Date: 09/17/2024 12:35 pm
Gas Tank Sending Unit
Date: 05/22/2018 02:17 pm
Date: 06/22/2017 07:19 am
Date: 09/02/2021 08:21 am
Date: 08/06/2021 02:23 pm
1974 Wiring diagram free
Date: 10/27/2019 06:56 pm
1972 Pinto SCCA BS race car
Date: 10/23/2018 04:01 pm
1973 Interior parts wanted
Date: 01/02/2017 11:02 pm
  • Online today: 1,044
  • Guests: 964
  • Total: 964
ford c3 transmission lines
Started by lefty, October 23, 2011, 12:09:43 AM
RSM
I could be wrong but I believe the one towards the front of the transmission is the pressure side...If I'm wrong it will be good to know since i have to plumb a cooler into my wagon at some point in time. The transmission out of my drag car had a hard line going from one fitting directly to the other. Now that it will be street driven I'll need a cooler.
Heading back to work in a few, but I will check my trans shop manual later and find it for you.
lefty
I don't have any lines to go by I am making them from scratch....
lefty
these two inlets on the """"transmission""" are both on passenger side of transmission I need to know which handles pressure and which handles return...
lefty
 return line which inlet on the transmission mission does it screw into   there are two inlets on the transmission -
thanks..
Return line should be on the passenger side and pressure should be on the driver side.
lefty
on the c3 which transmission  line is the flow back from the radiator and where does it go on the transmission itself?? there are 2 places where the lines screw into the transmission ...  thanks in advance...
Lefty
