Date: 09/12/2018 04:07 pm
Date: 12/24/2016 04:13 pm
2 Pinto Wagons for Sale
Date: 10/29/2018 02:02 pm
Custom Pinto Project
Date: 06/12/2016 07:37 pm
Date: 03/25/2019 09:02 pm
convert to stick
Date: 05/19/2018 09:26 pm
Date: 06/07/2018 01:45 am
2.3 front sump oil pan
Date: 02/19/2017 03:24 pm
Date: 09/19/2019 04:43 pm
  • Online today: 2,819
  • Guests: 2789
  • Total: 2789
simple fat bumper fix
Started by JoeBob, September 25, 2011, 11:56:41 PM
I'm sure there's a way of doing it, may have to fab some brackets??..
Quote from: 74 PintoWagon on August 10, 2014, 07:45:56 AM
Well, you're not alone I have one on mine too..  :D
I wonder if this is either a wagon thing, or only a 74 wagon thing?
Oh, well. Might have to do the rear Bill's way and see what I can come up with for the front. Someone mentioned taking the reinforcement off and bolting the bumper straight to the mounts. If I remember right the only thing about that is it doesn't bring the bumper all the way in.
If I get the energy to do anything again I'll try it.
Or maybe I'll get rich and just buy the small bumpers. hahahahaha.
When I do the bumpers on the 80 I'm only going half way in & cutting the fillers down. When they are pulled all the way in it looks too stubby in the front. The rear looks better all the way in but the sides are too long where they wrap around. I thought about cutting 4 inches out of the sides in the rear & seeing if that helps the look.
I don't know. I haven't tried to do this yet, I was just looking at the frame and noticed it.
Leave it to me to always have something odd.
Clydesdale80
hmmm... that is different.  it actually looks like the hole directly above the sway bar mount would correspond to what we used but yours is moved up on the rail.  Is there anyway you could vertically slot the back hole in the bumper mounts enough to use that upper hole and still be at the right angle?
It's a 74 wagon. The front sway bar frame mount bracket is in the way of moving the bumper frame mount back. It looks like the sway bar mounting hole would be the one I need for the rear most bolt.
Here's a picture. I measured the holes, and the sway bar mount is the right distance away if the hole in the bumper bracket is modified like Bill says to.
Clydesdale80
Quote from: russosborne on August 08, 2014, 01:42:44 AM
Dan, were you able to do this just the way Bill showed?
My car seems to be different.
yes, this was done exactly the same as how Bill showed except for the order of assembly.  What is different about your car and what year is it?
fuzzy
thanks so much  because I have found a 78   but haven't found a 79 yet   thanks again
Quote from: fuzzy on August 08, 2014, 07:08:18 AM
I have a question hope some one can help.   would bumpers for  77-78 fit a 79?
YES they will fit and so will Fairmont of the late 70's.
Quote from: dga57 on August 08, 2014, 12:24:21 AMI would gladly swap my '72 Squire for a '74 or newer in equivalent condition just for that reason.
Hmmm, now there's a thought... ;D ;D
fuzzy
Quote from: Clydesdale80 on August 06, 2014, 10:18:39 PM
For anyone that wants to see what this looks like on a pinto instead of a bobcat here are my results
I just noticed something that could be an issue. I don't see a front sway bar on Bill's car. I was looking at mine, and it looks like the sway bar mounting bracket could be in the way for the front bumper mount.
I only eyeballed it, so I could be wrong. Hopefully I am. But on mine it looks like that would be the second hole that Bill used, there is nothing else close that would be level.
His also looks like it mounts higher on the frame than mine . Maybe I am wrong. A Bobcat shouldn't be that different on the frame stuff, should it?
Dwayne, I will gladly swap bumpers with you. You pay for the shipping of the big ones, I'll pay for the small ones. ;D ;D ;D
Quote from: Pintopower on August 07, 2014, 06:47:28 PM
For a man that drives these daily and has been backed into, rear ended and bumped countless times, the stock deals are all I will ever use. I mean they do stick out but boy do they work! Weirdly, I think I am the only one that prefers the look of the big bumper cars.
No, you're not alone; strange as it may seem to some, I prefer the stock look of the big bumper cars too.  I would gladly swap my '72 Squire for a '74 or newer in equivalent condition just for that reason.
Pintopower
For a man that drives these daily and has been backed into, rear ended and bumped countless times, the stock deals are all I will ever use. I mean they do stick out but boy do they work! Weirdly, I think I am the only one that prefers the look of the big bumper cars. To each is own, this is why we have a world full of variation. Otherwise life would be boring, like with the mustang owners. ahahahahah!
#1. 1979 Wagon V6 Restored
#2. 1977 Wagon V6 Restored
#3. 1980 Sedan I4 Original
#5. 1980 Wagon I4 Restored
...Like i said, I like them.
...and I have 4 Fiats.
Quote from: dianne on August 07, 2014, 02:50:49 PM
Yeah, really an awesome look!!!!
Yeah, anything looks better than that battering ram sticking out there, lol.. ;D
Quote from: 74 PintoWagon on August 06, 2014, 10:22:25 PM
That looks good, and thanks for the tip..
There you go Art, now you can lose those bumpers you don't like :-D
Clydesdale80
I think it looks angry in this pic ^...    I like it  ;D
This is a 78 ( aluminum bumpers  8) ) but I swapped out my headlight rings for the early style.
Also if you would like to make the bumper install easier and eliminate the use of excessive ratchet extensions then just bolt the mount to the bumper before bolting the mounts to the car.  a box wrench can then be used to loosen the bumper bolts just enough to level and adjust the bumper.
Now THAT'S a gorgeous yellow Bobcat! Beautiful car!!
I understand Racer Walsh does not sell the 1" blocks anymore. I think the blocks for a Ranger PU are the same with the oval boss that fits into the spring pads. You must have that boss to keep the rear end in place. With only 1" blocks the stock u bolts will still work. Go for it!!!!
Thanks Jack. I'm going to come up with about the same idea on mine. I'll use 1/8" ABS plastic and a big heat gun to form it around the fenders. Now you need to get it LOW.
Jack! Tell us about the air dam. Looking good like a Pinto should.
Great info guys, looks like it's not a hard project after all..
Thanks!
Worth looking into.
Thanks!
Didn't know that.
