NOS Sedan decklid
Date: 10/23/2019 11:51 am
Date: 06/07/2021 08:14 pm
1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
Seeking 1971-1973 Rotors
Date: 04/08/2021 12:23 pm
TWM Intake
Date: 08/15/2018 08:20 pm
Need 72 pinto parts!
Date: 06/14/2019 01:40 pm
Date: 09/22/2020 11:33 pm
79 pinto steering column
Date: 08/18/2018 02:00 pm
sport steering wheeel
Date: 10/01/2020 10:58 pm
  • Online today: 1,044
  • Guests: 929
  • Total: 929
Wagon side/rear window removal
Started by popbumper, September 19, 2011, 09:40:54 AM
Quote from: Fred Morgan on September 21, 2011, 01:16:46 PM
Chris I have good seal for $35.00 total shipped.   Fred   :)
Fred:
  Will remove this weekend, if they split/tear, I'll be in touch, thanks!
carbomb
i took mine out to replace them with side panels from a crusing wagon. The front one is fairly easy because it just has 3 skrews on the one side but the other has some odd clips that i broke because i didnt need them or care for that matter. the back one is almost as easy. just took working the gasket out with skrewdrivers and pushing out on the window until you get it started then it comes right out
Phil, I would very much like to know what the rejuvinator is so that I can find some, if you have the name handy. Thanks.
chris
i have never pulled the rear side window but did the pop out one  it was easy because  the window was not in the seal and i did  pull one from the hatch  by taking the molding out first . on  a trunk mode  it was the same  take the molding out first
as far as i know there is NO replacement  for the seal. once you get it out  there is a rubber reguvinator  product  out there i work at a print shop and we  use the regunivator frequently i have tried it at home  and it does soften up the rubber. but it eats paint as well.
Has anyone successfully removed their rear wagon quarter windows successfully without completely destroying the seals? Are there any recommendations for replacement material (seals) from any source that is close to the originals should they tear? Thanks.
