1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
1976 Pinto runabout
Date: 03/28/2017 08:14 pm
Date: 07/08/2017 08:53 pm
Crane Cam
Date: 02/26/2018 07:50 am
1973 Pangra
Date: 01/06/2015 02:19 pm
Beautiful 1980 Pinto
Date: 04/13/2020 11:53 am
turbo 4 cyl and aod trans
Date: 12/14/2019 04:55 pm
pinto parts for sale
Date: 07/25/2018 04:51 pm
79 pinto steering column
Date: 08/18/2018 02:00 pm
  • Online today: 1,044
New parts ordered
Started by Reeves1, September 04, 2011, 07:59:57 AM
That sure looks pretty. I never knew there was a short pump setup.
I picked up the long water pump stuff off the clearance table at Summit over the last 2 years. Aluminum pump(25), billet alt. bracket(40), chrome alt.(25) & March v-belt pulley set(100)
pintoman1972 - water pump has a back plate.
Only part not here yet is the alt fan. (could be sitting at the Post Office right now)
Timing chain cover, short water pump, brackets & pullys. (some bolts not in picture)
I'm not sure if it will require a backing plate ?
New link shows the timing chain cover:  http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=26
Looks like maybe just a gasket ?
Sort of off topic.....
Been thinking of making a "Pinto Kit".
The 302w & tran will be pulled soon. Going to tear down & get specs from the pistons & cam. Maybe put a good set of heads on it.
I have a line on two 9" diffs.
So , I'd be able to put a full package together from front to back.
First priority is to get mine back running though....
Anyone interested ? Shoot me a PM asking for more details.
pintoman1972
Does that water pump require a backing plate?
If I have time etc. I'll put the parts in place before I pull the 302w & take pictures.
It may help others in the same place....
The original BOSS 302 & the 302w that is in it right now both sit too close to the rad. Maybe 1/2" or closer. Rad is in front of the rad support.
This will allow the fan the needed clearance from the rad & rad support.
Rad will still need to be in front.
At least in my car. Might have to do with how my engine is mounted.
Parts will not be "tested" till this winter. New BOSS 302 is still sitting in Chicago.
New parts will allow a bigger fan and more clearance.
Thought about other options & went with a factory BOSS fan. Maybe. I'll see if there is enough room......I'll be posting pictures when done.
RSM
Let me know how that alt bracket works out. I have to do that on my Squire and was wondering how high up the alt mounts with a bracket like that. The short water pump would be nice on mine but I'm using a reverse rotation with power pulleys. I'm going to wind up with the radiator in front of the support.
Short water pump. Will give me 1.5" of extra space. Providing it works on a BOSS 302 engine !
http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=5532
Brackets.
http://www.cvfracing.com/Ford-289-302-Alternator-Bracket-1969-p/302-altbrkt-d.htm
Pulleys.
http://www.cvfracing.com/Short-Ford-Small-Block-Pulley-Kit-Alt-p/sbfs1kit-fr.htm
Alternator fan.
http://www.cvfracing.com/alternator-fans-s/126.htm
The picture of the required timing cover is missing. Found a place in Edmonton that has it in stock & will be sent to me on Tuesday.
