74 & Up Parts
Date: 01/20/2021 03:22 pm
I need a 1976 hood
Date: 12/19/2016 06:02 pm
Date: 08/13/2018 02:46 pm
78 pinto wagon
Date: 03/03/2020 01:07 pm
Date: 05/03/2024 05:37 am
Date: 10/03/2018 10:46 pm
1977 Pinto Cruizin Wagon
Date: 08/07/2023 02:52 pm
77 Caliper Bolt
Date: 08/21/2018 04:02 pm
Date: 10/24/2019 01:43 pm
  • Online today: 134
  • Guests: 123
  • Total: 123
Lowering a pinto
Started by LouisD, September 01, 2011, 08:04:05 PM
Grumpy
If you are going to lower, do it right. You will avoid bumpsteer problems by using these...
http://www.heidts.com/mustang_ii_2_dropped_steel_spindles.html
They are available from Fat Man's as well and these are forged steel, much stronger than stock.
In addition, get some 11 inch brakes to go with them. They are Granada based with GM single puck calipers(get the big piston ones for manual brakes)...
http://www.heidts.com/mustang_ii_disc_brake_conversion_kits.html
Grumpy
79 Pinto Hatch, Yellow w/White Pony stripes, Pony wheels, 6650 miles
80_2.3_ESS
Quote from: dennll on February 29, 2012, 05:04:08 AM
Nick, what brand rims are those?
They are a set I picked up at a swap meet for 50 bucks. They looked like they had sat in a barn for 25 years. They had so much oxidation on them. Took me and my dad a full weekend of sanding and polishing them to get them that good looking. The brand itself is "Western Wheels".
They were the older "uni-lug" set-up with the slots for the lug-nuts to fit different bolt patterns. They are not new wheels, so I cannot give you a good place to look for them.
Nick in CT
1980 2.3L Pinto ESS
dennll
Menace Kustoms
That just doesn't look lowered at all to me. It's cool, just not low.
80_2.3_ESS
Quote from: dennll on February 26, 2012, 09:19:04 PM
Sorry, resurrecting this thread, but I think it's relevant...
Has someone worked out the formula for maximum wheel/tire size with respect to stock wheel well clearance and lowering? I see a couple tire size recommendations here based on how much the car is lowered, but would be nice to have a rule of thumb to work with. Figured into this rule would be how much clearance you need to leave for suspension travel, turning, handling characteristics. Anyone?
On my car, an 80 Pinto, I have Racer Walsh lowering springs in the front that my dad put into the car back in the early 80's (yes, the car is a "hand-me-down" lol). for the rear, we took out the blocks between the springs and rear-end, which raised it a little. Gives the car a mean looking rake to it. Also has a Mustang II 8" in the back, not sure if that alters the ride height at all.
As for tires, I am running 14's all the way around, I think they are 8's in the back and 7's in the front. Back tires are 245-60-14's, and the fronts are 205-60-14's if I recall correctly. No rub in the back, and just minor rub in the front when the wheel is turned all the way to one side or the other.
Nick in CT
1980 2.3L Pinto ESS
Menace Kustoms
Hmmm, that's almost low enough . . .
lefty
Lowered mine 3" front and back -shorter springs on front-3 " lowering blocks on back.  Run 14" rims on front and 15"rims on back
dennll
LouisD
All good stuff to know guys! Thanks for all the help!
PintoMan1
i have lowering spindles on my '73. just had to have the tie rod holes reemed out alittle to fit stock tie rod ends.
1973 pinto runabout
My '80 has 83K garage kept miles & the rear springs are firm so the lowering blocks are perfect for her. It will not see over 150 HP so wrap up wont be an issue. I do have new Moog spring & shackle bushings as well as spring isolators so all slop will be gone when I get back there & replace everything.
As stated, lowering spindles don't fit '71-'73 models.
If your springs are solid you can have them de-arched at any spring shop. It used to run about $35 bucks to do a pair but that probably went up some. I don't recommend blocks if you plan to exceed 300 HP either unless a good set of ladder bars is included out back.
LouisD
LouisD
^ Thats a good plan for the bus. Its so much fun camping and cruising around in some old vw's. And if you ever get  bored, feel free to drag one of the 7 down to florida lol. Tow it with the bus and make a road trip out of it! Then we can hit up some FL campsites vw style! lol
Quote from: LouisD on September 04, 2011, 05:02:55 PM
Thanks! That's a very nice '70 you got there too! So whats the plan for it? Slam? Stock? Love the slight patina! Its a fine example, make sure you get on earlybay then lol.
Thanks Bruce, I'll check that out!
Still need to find a car..... Pintos seem to be far and few between around FL.
The plan is to just clean it up and camp in it!! :D  Already joined EarlyBay!! Thanks for the link!!
As far as Pintos, to bad you didn't live closer. I have a few to spare! LOL I have 7 Pintos right now. :D
LouisD
QuoteYour Bay is so cool!! I love the paint!!
I just picked up a Bay today!! Here is the photobucket page on it!!! I'm so excited!
http://s106.photobucket.com/albums/m247/myhrdly/70%20Bus/
I'm justcruzin on the Samba!! Guess I can join that early Bay forum now too!
Bruce, good call on springsnthings.com they have the parts I'm looking for, spring pads etc..
baflinn
Louis, I had a set of rear leafs built with a 1" de-arc (drop) by this shop in PA they can go as far as a 2" drop and the product is top notch. Lowering blocks will not help you as much as a de-arced spring if you're looking to build a racer. The block while lowering the ride height doesn't change the spring dynamics and if you're running old springs they're gonna be spongy. If you buy generics from JC Whitney or someone else you may not get a matched pair and everyone else selling them I found to be more expensive.
Shop around and do a comparison - granted I bought mine a few years back so the prices may have changed but it's worth a look.
http://www.springsnthings.com/leaf-springs
I have bought many of my suspension parts from them and have never been disappointed. - BruceF
Liquidating all Pinto related parts.
Current list can be found here: http://www.flickr.com/photos/bruceflinn/8007178278/in/photostream
I just picked up a Bay today!! Here is the photobucket page on it!!! I'm so excited!  ;D
I'm justcruzin on the Samba!! Guess I can join that early Bay forum now too! :D
LouisD
Quoteit is a very tried-true & effective way to lower the rear of a leaf spring car to enhance handling & steer clear of excessive leverage/torque acting on the rear suspension as a result of increasing the dimension from the leaf spring mounting pad to the axle tube centerline.
it works. it aint cheap, but it is a tried and true method.
I'll do some researching on this. Any info on how it is done?
QuoteOn the lowering spindles, they are made for the 74-80 suspensions and will not fit the 71-73 suspension.  Your former blue Pinto appears to be a 71-73 model.  Not sure what you are looking to get.
Racer Walsh also has a free paper catalog that is much more user friendly than their web page for this stuff.
Hmm, I'd prefer an early model but I can always retro fit an early front clip. I plan on getting pretty much what ever I find for the right price lol. Already ordered the walsh catalog :D
QuoteHere is a link to my photobucket page for the bus.
http://s106.photobucket.com/albums/m247/myhrdly/VW%20Bus/
Do go to The Samba forum?
Very cool! Ya im on samba, sn: hightopbay.  Here's my build thread for the bus so far on earlybay.com
http://forum.earlybay.com/viewtopic.php?f=2&t=31242
Quote from: LouisD on September 01, 2011, 10:10:56 PM
And very cool pintogirl, any pics of them?
The easiest way to lower a Pinto is to leave the saggy, worn out parts on it... If my car sat any lower it would drag the ground all the time.  :lol:
as far as de-arching leaf springs goes "....de-arching springs are (sic) old school .."
I don't know about every set made but most are designed to use the stock 9" brakes. There are a couple cast for GM rotors & calipers as well.
LouisD
sweet! Do you happen to know if the stock brakes will bolt on the ebay drop spindles without the ebay caliper bracket too?
Pinto5.0, where do you get the drop spindles from?
I got lucky & found them on the scratch & dent table at Summit minus the original box for $75 but Ebay is loaded with them as is Speedway.
LouisD
Thanks for the heads up D.R.Ball, I'll give walsh a call.
To lower my son's 4 cyl. '80 I got new rubber isolators to keep the squeak away & an old set of cast steel, not aluminum, 2" Racer Walsh blocks for the rear & a set of forged 2" drop spindles for the front. Combined with 215/65/14 front tires & 255/55/15 rear tires I should get a good rake & fill the wheelwells & still maintain stock suspension travel & near stock ground clearance.
For my V8 car I'm kicking around airbags to drop on demand.
That's the 2 common ways. Cutting coils & de-arching springs are old school methods.
I have no idea how to lower a Pinto, but I just wanted to say that you sound kind of like me! THat is in the reguards of the cars you own! LOL I too own a VW Bus and a Miata!  ;D
