79-80 full glass hatch
Date: 01/04/2017 04:04 am
1973 Pinto Pangra
Date: 07/08/2019 10:09 pm
Date: 08/05/2018 01:58 pm
Date: 10/11/2019 11:13 am
PINTO TRUNK LATCH & CATCH
Date: 03/23/2018 09:39 pm
Date: 08/01/2018 01:17 pm
Esslinger 2.0 intake
Date: 03/06/2017 11:58 am
Bumper Guards
Date: 03/28/2017 09:27 pm
78 pinto wagon
Date: 06/04/2020 12:42 pm
  • Online today: 600
Auto Trans leak
Started by johnbigman2011, August 28, 2011, 07:59:42 PM
johnbigman2011
Dave1987, thanks for the info. Under the car I go as soon as I get home from Papua New Gunea.
Thanks again.
It is an o-ring with a funny outer sealing lip. It is fairly easy to replace. It is called a shift(er) shaft seal.
The transmission in your car is a Ford C4.
It requires the trans to be drained and pan dropped. Then the valve body has to be removed and there is a nut inside that holds the shifter shaft in place. Once you get that nut removed it can be withdrawn out the side of the case and the o-ring can be swapped out.
When you reinstall the valve body, be sure to tighten down the bolts from the middle outwards or you can get low pressure to it and bad shifts causing your frictions and steels to glaze quickly.
In my 73 station wagon the transmission mount has to be removed and the transmission tilted back somewhat, because the shifter shaft cannot be withdrawn from the case completely due to lack of space between the case and the trans tunnel.
While you are in there, I would recommend doing a filter change as well.
johnbigman2011
Sorry not sure of what year the trans is? 71 to 73 auto that is leaking from the shifter area on the side. Is this a major fix or is it a gasket or o ring repair?
Thanks for any help or ideas.
