free transmissions
Date: 11/28/2019 10:21 am
78 fender and hood
Date: 03/23/2021 01:07 pm
Date: 02/05/2020 11:06 am
WANTED Hood Prop Rod
Date: 01/17/2017 02:47 pm
Date: 07/17/2018 09:49 pm
Date: 10/26/2020 03:24 pm
Date: 09/03/2018 08:58 am
Date: 12/30/2022 01:30 pm
71-73 sway bar
Date: 06/12/2021 10:12 am
  • Online today: 1,431
  • Guests: 1158
  • Total: 1158
Shocks
Started by brians89stang, August 24, 2011, 08:00:08 PM
Starliner
I think we are missing the point...   the tires should not rub even if you hit a bump.
You need to solve why the tires hit during normal suspension travel.
1973 Pinto 1600 - Sold!
1979 Pinto 2300 - Sold!
82expghost
is there a differance between the shocks on the mustang ii? if not, they make bilstiens, and pro stock shocks, the pss are better, thats what im running with a pair of landrum 150# springs, you will feel like a bobble head thoe while driving it
98 taurtus, now in heaven
77 pinto, weekend warrior
92 grand marquis, daily
I've had good luck in the past using trailer towing "helper" springs on the rear leafs or just adding another leaf. A relatively cheap way to go. Check PEP Boys or J.C. Whitney. It might raise the height a slight amount if your springs are already "soft" from age.
Starliner
I am guessing the Mustang rear axle is wider.
You should investigate finding rims with a different offset.
Go to this link and scroll down to the section named "wheel tech"
Link:   http://www.tirerack.com/about/techcenter.jsp
This should help you determine if a wheel change is a solution.
Do the tires rub when turning into a driveway or when you hit a bump in a turn?
If so, front and rear sway bars also help because it reduces body lean.
RSM
Just don't hit any big bumps LOL..from what I can see it's really close on clearance. I haven't seen any shocks that would do what you want. A smaller tire might be the way to go. I haven't got my wagon on the road yet but I'm hoping I dont have issues with the rear tires. This is the link to my photobucket.  http://s989.photobucket.com/albums/af17/RSM1961/Pinto%20Wagon%20Build/
brians89stang
I'm not sure how to post pics on hear but I have a photobuket album under brian89stang if you want check it out .
brians89stang
Here's my problem ,, I have a 73 trunk pinto its got a 8 inch mustang 11 rear end & I have a 8 1/2 rim & 295/50/15 tire . Beleave it or not it fits really well . The problem is when I hit big bumps they rub the outer fender well . It has the original shocks on it , is there any stiff shocks avalable to help me ?? I really like the way the car looks & sits with this tire combo .. Thanks for any imput before I just put smaller tires on it .
