Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
Pinto Wheel Well Trim
Date: 03/29/2017 11:35 am
95 2.3l short block
Date: 03/18/2017 04:54 pm
Date: 03/27/2017 10:07 pm
1977 Left Side quarter panel
Date: 06/10/2019 04:16 pm
Front sway bar frame brackets
Date: 07/13/2017 01:05 am
Pinto brake booster needed
Date: 05/08/2021 09:00 am
72 Pinto parts
Date: 12/04/2018 09:56 pm
Date: 02/18/2017 05:55 pm
  • Online today: 1,044
  • Guests: 79
  • Total: 79
Changing lug pattern on the front of a 1971 with discs
Started by ahawes, August 10, 2011, 10:48:38 PM
ahawes
That seems to be the most viable option at this point. For some reason it just scares me a little to only have that article to go off of without seeing it all more closely. If/when I make the leap that's probably the route I will go.
71 Runabout
I believe a few were asking about swapping in 74-80 spindles for which 5 lug set ups are available.  The later spindle is significantly taller and I suspect it would throw off the geometry without further modifications.
The one I liked was turbopinto72's use of Granada 5 lug rotors, GM metric calipers, and modified brackets intended for later Pinto's.  Maintenance parts can be obtained at most parts stores.
ahawes
I missed that thread on my searches last night somehow. Thanks for posting it up. So I notice there was mention of changing the ball joints and completely swapping the spinde w/ brake and all. What ball joint swap would this be and what spindle would you wind up with?
71 Runabout
The thread below has a great discussion on converting the early Pinto disc spindles to 5 lug with larger rotors.
http://www.fordpinto.com/pinto-faq/front-disc-brakes-(4-5-lug)/msg8025/#msg8025
ahawes
How difficult is it to get a Ford 5 lug front disc for the early Pinto? Looking at swapping the rear with a early Mustang 8" and would rather swap the front discs to 5 lug rather than the rear's axles and drums. Seems to be more options in the 5 lug for wheels anyhow.
71 Runabout
