1977 Left Side quarter panel
Date: 06/10/2019 04:16 pm
1980 Pinto Pony for sale
Date: 08/21/2021 03:54 pm
MISC PINTO PARTS
Date: 08/27/2017 10:23 am
Date: 09/15/2019 12:28 pm
1977 Pinto Hatchback Parts
Date: 08/29/2020 05:31 pm
1978 RUNABOUT
Date: 04/01/2017 03:18 pm
Date: 12/31/2017 11:14 pm
77 pinto cruz. wagon
Date: 06/15/2017 09:18 pm
Date: 08/08/2017 01:44 pm
  • Online today: 146
Aerostar Driveshaft swap
Started by dave1987, August 06, 2011, 12:00:30 AM
bbobcat75
sweet will be looking for one for the wagon
thanks for the info
eric
1975 mercury bobcat 2.8 auto
Quote from: bbobcat75 on August 06, 2011, 08:43:00 AM
what year aerostar van is needed for the swap and what model van?? and is it for a hatch/ sedan or a wagon??
first time hearing about this!!
thanks
eric
Should work on sedan,hatchs and wagons since they all use the same wheelbase....As for what year if i remember right its like 92-97 and they have to be the AWD ones. The 92-95 have pressed on end caps on the driveshaft and the 96-97 have welded on caps but either one will work.
bbobcat75
thanks
eric
I did the AWD Aerostart DS swap on my 86 Saleen last fall.  I used my original yoke and flange for the 8.8 (due to them being smaller) and have no problem with balancing so far.  For comparaison sakes, my original DS weighed 17 lbs assembled.  The Aerostar DS weighed 9 lbs using my original yoke and axle flance.  Not a bad weight reduction.2
Lighter than the steel Pinto drive shaft, it is made of aluminum.
bbobcat75
what is the benifit of using a areostar drive shaft??
thanks
eric
I will be doing this swap on my 78 Sedan next week and was wondering...
If I do a yoke swap, to use the Pinto swap instead of the Aerostar Yoke (same splines), do I need to have the shaft rebalanced? From what I can tell with online videos, drive-shafts are balanced without any couplers or yokes attached to the shaft.
