Date: 02/05/2017 09:45 am
TWM Intake
Date: 08/15/2018 08:20 pm
Date: 09/19/2019 04:43 pm
Date: 12/10/2017 01:14 pm
Need Interior Panels
Date: 07/09/2018 04:59 pm
Hoard of Pinto parts
Date: 12/17/2016 04:14 pm
79 pinto small parts
Date: 04/24/2019 03:16 pm
76 Pinto Wagon
Date: 07/08/2020 05:44 pm
1976 Ford Pinto Pony
Date: 09/06/2018 05:40 pm
  • Online today: 624
  • Guests: 385
  • Total: 385
Oil pan removal
Started by Bobcat Racer, August 05, 2011, 11:13:18 AM
on a 2.0 (71 or 72 -not sure about 73) remove the top nut from the motor mounts and jack up the motor so that it sits on top of the motor mount studs.
remove all the pan bolts and separate the pan from the block.
using the correct tool & a 3/8" drive ratchet, remove the oil pump bolts & drop the pump into the sump of the pan.  (don't forget to keep track of the oil pump/distributor drive hex shaft-it MAY fall out & into the pan)
once the oil pump has been dropped the pan will slide out toward the front without too much trouble.
DBSS1234
It can be done but you need to drop the steering rack and unbolt the engine mounts and lift the engine up for more room.
I never had luck trying to on the 2.3L or 2.0L....
Sorry
FrankBoss
Bobcat Racer
My current oil pan is leaking at a rate of about 1 qt of oil ever 2 weeks.  Is it possible to remove the pan without taking the engine completely out of the car?
