  • Online today: 642
  • Guests: 227
  • Total: 227
5 lug pinto rotos
Started by docsdream, August 02, 2011, 12:52:21 PM
Quote from: Pinturbo75 on August 03, 2011, 07:32:07 AM
granada rotors, gm calipers and metric brackets from speedway is probably the cheapest way....
Actually the cheapest way to do the front is just buy http://www.speedwaymotors.com/5-Bolt-Mustang-II-Rotors,1964.html they are stock size if all your wanting is 5 lug! Otherwise go the metric caliper/granada rotor route.
80_2.3_ESS
I bought a set off eBay, can't remember the company. I think the cost was like a little over 3 bills. Came with drilled & slotted 11" Rotors, calipers, brackets, brake pads, and all the needed hardware and brake lines.
They bolted right on, and they stop the car on a dime. To finish my 5-lug conversion, I had the axles in my rear end re-drilled by my uncle, who is a machinist for a living. My rear end is a Ford 8", and I went a little cheap instead of buying a whole new set of axles. I then used backing plates, brake pads, and brake drums that were meant for a fox body mustang 5-lug conversion.
Nick in CT
1980 2.3L Pinto ESS
Also go to Moser for the axles on the rear end, they can make a custom set of 5 lug for the Pinto complete with bearings pressed on and you will need Ford Ranger 5 lug brake drums for the rear. They are the same size rear drums as the Pinto.
5 lug Mustang II Swap Rotors from Speedway... in most cases they are cheaper than new 4 lug rotors from a autoparts store.. bolt on too.
FrankBoss
docsdream
I want to switch my '78 Pinto to 5 lug rotors.  What would be the best rotors to use?
