Date: 06/30/2018 09:48 am
Date: 09/12/2018 12:33 pm
1974 Ford Pinto Squire Wagon
Date: 05/30/2020 01:51 pm
Date: 10/03/2018 10:46 pm
Date: 10/05/2017 02:26 pm
Date: 09/02/2021 08:21 am
Date: 11/05/2016 09:03 pm
74 pinto
Date: 09/11/2016 06:32 pm
  • Online today: 1,044
  • Guests: 61
  • Total: 61
Parting out 1979 Bobcat on Tuesday
Started by dave1987, August 01, 2011, 12:28:21 AM
poorking02
i have interest in some parts  can i call u  need phone number     larry king  559 908 0495
email   larryking@pacbell.net   thanks
Bummer. I was hoping for a saddle color for Wildfire. Her vintage '74 armrests are toast. And just about as crumbly too...
The door panels and armrests are a chamois color. The dash is nearly the same color as brownie's dash. The carpet was at one time the color of the new carpet I put in Brownie, not a dark saddle brown but bight mid tone brown.
Hood hinge boots are torn and rotted, no go on that. Sport mirror only on driver side, left it.
Chrome trim around the windows were gone, someone got it first. :(
No hatch handle, turn signal lenses are cracked, marker lights broken, dash cap destroyed, wiper linkage broken on passenger side, seat belts don't retract, door felts and seals were rotten and broken.
Here is what I did get:
Three of the four wheel well moldings (front driver side was badly damaged).
Grill
Tail light lenses
Top and sides of windshield trim
One steel styled wheel with trim ring (will use for my spare tire)
Top of air cleaner (for my 78 sedan)
Armrests
Kick panels
Rear view mirror (for my 78 sedan)
Door panels
Steering column plastic
Steering wheel button (didn't have my bolt puller with me to get the wheel)
Turn signal lever
Hatch hinges (pins missing, but chrome in great shape!)
Center AC vent and side dash vents
Gauge cluster assembly (in good shape)
Door handles and window handles (inside)
Plastic cover for ebrake handel body
E-brake cover
Door sills (that hold the carpet down)
Rear marker inside panel access covers
Wiper and light knobs
I plan to go back to get the following before the car is gone:
Shifter handle and woodgrain shifter bezel (didn't have my hex key wrench set)
Outside door handles
Bottom of windshield trim
Rear side glass (passenger and driver side)
Sway bar
Steering Wheel
Turn signal switch
Power steering brackets and hoses
Fuel sender
Filler neck
Brake lines
Transmission lines
Radio bezel
Center cubby
Dash woodgrain panel
Wiper and light switch rings
are you talking about the stone deflectors? Made of a rubber type material?
I have a set from a 78 bobcat station wagon that I parted out a couple years ago, complete with the metal "frame" strips that they staple to. They are a brown "glow" color that Matt's 78 used to be before he painted it blue. I was keeping them around for when I paint my 78 sedan again, but if someone needs them, I've got 'em. (These are for the big aluminum bumper Pintos/Bobcats from 77 to 78)
RSM
something to grab if they are in good shape are those 2 filler strips that are between the grill and bumper...not sure what the technical name for those are. Took me a long time but I found a useable pair.
I will find out tomorrow.
t appears they car was covered or under a shaded tree most of it's life. The strips on the car are still on there, while not bright, they are complete. The paint is in pretty good shape, could use a buff but it's still dark and not cracked or rusty underneath the top half of the car (Haven't looked at the bottom).
Will take before and after shots :)
RSM
What kind of shape are the hood hinge boots in?? If they are in very good condition I'll take them!
It is a hatchback.
I may be keeping the driver side fender to replace on my 73 station wagon when I repaint it, unless you need it of coarse, it will be a couple years before I can repaint my station wagon.
It would be a bit hard to ship fenders though. I am in Idaho, very near to boise. In fact my storage unit is in Boise. Any chance on a road trip?
75bobcatowner
Are you selling the front end and the front fenders?
sedandelivery
Here is what I am pulling for myself:
Rear view mirror
Door Panels
Steering Wheel
Front Seat Belts
Shifter Bezel & Knob
Steering Column Plastic
Radio Bezel
Glove Box Door
Center Cubby
Wheels & Trim Rings
Door Glass
Power Steering Pump Brackets & Hoses
Fuel Sender
Door Handles (inside & out) & Window Knobs
Light & Wiper Knobs + Rings
Air Cleaner
Window Felts
Door Seals
As always, what I don't actually end up needing or wanting much is always available to you all!
And the rest that I am pulling:
Dome Light
Wheel Well Moldings (If on the car)
Rocker Moldings (If on the car)
Window Moldings
Armrests
Front Swaybar
Kick Panels
Grill
Taillight Lenses
Hood Hinge Boots
Gauge Cluster
Dash Cap
Wiper Linkage
Turnsignal Lenses
Windshield Molding
Dash Woodgrain Panel
Dash vents
Anything else anyone wants? All of those items will be available, and what does not go in the first week or two will be stored away in my storage unit until someone needs something.
