Automatic Wagon
Date: 06/14/2019 11:22 pm
Date: 06/25/2021 12:59 am
Date: 01/28/2017 12:30 pm
Date: 10/25/2019 04:05 pm
Date: 02/08/2018 02:26 pm
71-73 sway bar
Date: 06/12/2021 10:12 am
Date: 07/17/2018 09:49 pm
Brake rotors
Date: 03/24/2017 09:02 pm
1978 Squire wagon 6 Cly
Date: 02/16/2020 05:42 pm
  • Online today: 1,044
  • Guests: 58
  • Total: 58
New Pinto! Engine Problems
Started by morpheus256, July 31, 2011, 06:44:35 PM
RSM
   Something to look at on that engine is the carb. I had one last year that was kinda doing some of what your talking about. The bolts that hold the base plate to the bowl were loose. I was doing something around the carb and bumped it. When I did it moved. So after checking things out is when I found this problem. It ran better after I removed it and tightened everything back up. It's something you might want to check.
   If the plugs are wet with oil sounds like a ring issue. If you had a blue smoke on acceleration or deceleration or a blue puff of smoke when you start it then that would indicate valve guides. With the compression you have I would lean toward rings.
morpheus256
Well, I think we have bigger fish to fry. I've hooked up the lines bypassing most of the smog components, Dist to carb, Egr to carb, manifold vac to choke pod. and a rough stumble still occurs at idle when cold, after it's hot it's a lot better.
compression in all 4 cylinders is ~95psi, the Lina  engine in the pinto is 9:1 or 8:1 CR?
Cold idle vac gauge swings quickly between 10 and 16" Hg
Hot idle vac gauge swings quickly around 14" (+_.3) Hg
I've adjusted the Dist for max Vac.
Checked the spark plugs and heavy oil contamination.
Unless I'm wrong, and I'd love to be told that I am! I think we're looking at either rings (blowby), or Valve Guides (sticking)
Thoughts?
Thanks!
Bone stock 79 Runabout
77pintocw
Hey morpheus256:
Below is a link to two pics for vacuum diagrams that I posted some time ago which might help some.
http://www.fordpinto.com/general-help/vacuum-diagram-for-1977-pinto/msg52690/#msg52690
Thanks,
77pintocw
1977, Pinto Cruising Wagon, White with Blue Graphics
morpheus256
after another look, there is no deceleration valve, the larger 3/8 line that runs from the plastic tank inside the driver's fender runs to a port to the left of the fuel line on the carb.
after doing some thinking, since we don't have air-care or any smog tests where we are, we'd like to remove all the Smog related vacuum lines, and de-smog the engine in effort to get it running right.
the Vacuum port coming out of the #4 runner goes to brake booster, and to a hard line that runs down towards the tranny tunnel (heater controls?)
the one coming out of the #1 runner goes to the rats nest the guy has created for me. I tried making some sense of it this morning, and made an even bigger mess of things and now it wont even idle with out stalling.
with everything disconnected from the #1 runner, applying some vacuum to the adv on the dist the engine seemed to smooth right out but it also speed up which makes sense.
Your car still has the deceleration valve on it? I recall a post about those a couple years ago...
Once your car backfires it burns up the diaphragm, rendering your decel valve inoperable and causing a huge vacuum leak. Try disconnecting it and plugging it to see if that helps.
morpheus256
Hmmm, that's interesting... the reason i say that is there is no metal can on the inside of the passenger side fender, or for that matter any Vac lines running into that fender. There are 3 Vac lines running inside the Drivers side fender, Two smaller one larger going into a large white plastic container, the larger Vac line runs to the deceleration tube on the carb. The previous owner played with the lines with all the masking tape notes to himself on them, I have a feeling he may not have put them back on properly judging by the lines running every which way.
Does anyone have a diagram for the 79' to illustrate how the lines should be routed? with any luck my problem's go away once I clean up the mess he's created :)
77pintocw
Hey morpheus256:
Not an expert on this issue, however, from my personal experience, Pintos
will really "buck" around if there is a vacuum leak especially during idling.
Not saying this is all your issues, but you got to make sure there are no vacuum
leaks before you start tweaking the carb and timing.  The one place to be sure to check is the
vacuum can that is located in between the passenger door and the body on the '79.  You can
see it by the upper hinge.  If there is a leak it will be in this can since it is located outside
the engine compartment and can easily get a rust hole in it.
Good luck with your new toy.
77pintocw
morpheus256
Hey!
My wife recently decided she wanted a project car, and I've always been a big on the 2.3T engines, Currently doing a conversion on my 87 Mustang so I nudged her in the direction of the Pinto. She just bought a 79 Runabout C3 2.3!
I'm having a couple issues with the engine, I'll admit that I'm a newb when it comes to Carb's so I've been figuring it out as I go but for the life of me I cant get it to idle as smooth as what I'm use to with my EFI 2.3, Runs very rough and wants to die once it's warmed up, Driving around it seems fine. I think I may have an issue with either the rings, or the valves (While the Mrs' was following me she says she saw blue smoke whenever I was getting heavy on the throttle) possible cam timing. hooking up a vacuum gauge the needle swings rapidly between 5 inches and 16 inches with a cylinder compression of 95psi on all 4 cyl.
the cylinder compression to me seems very low on my 9:1 EFI I get between 150 and 170PSI, and on my 8:1 Turbo I get 125 and 140 psi.
I've checked it over for vacuum leaks and can't seem to find any, but at idle I hear a hissing out of the carb coming from the choke butterflies.
Help?! :)
I'll get some pictures posted up on Tuesday, overall the cars in great shape with either 70,000 km or possible 170, or maybe 270, doubtfully 370 :)
Edit: perhaps this should have been posted under the "help" section... if a Mod sees this can you please move it? thanks!
