Date: 07/20/2018 03:00 pm
Date: 09/21/2018 11:35 am
Date: 02/10/2017 09:30 am
75 wagon need parts
Date: 05/28/2020 05:19 pm
1978 bobcat 4speed shifter
Date: 11/02/2023 09:51 pm
1971 Pinto Parting out
Date: 07/06/2018 01:11 pm
Date: 01/23/2023 02:22 pm
Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
Date: 06/30/2018 09:48 am
  • Online today: 1,044
  • Guests: 56
  • Total: 56
V6 miss
Started by flash041, July 20, 2011, 02:38:43 PM
RSM
If you do, check the lifter thats associated with the valve that tight. I don't know how much room is around the pushrod but If you can get a look at the top of the lifter through the pushrod hole, make sure it's not coming apart. I had the retainer come out on a lifter before and the plunger worked its way out. Didnt take long before it bent the pushrod and spit the lifter out of its bore. That was a mess. Wound up with numerous lifters coming apart. The older 454 Chevy's had that issue. It's just something to check. Hope you find the issue.
It has the shaft, and I have a spare so I might just change it out with a few pushrods as well.
RSM
There could be an issue with a lifter. I've had them come apart and actually wound up bending a pushrod. It's kinda weird that only one valve would be out of adjustment and it wound up being really tight. This might be something to look at if this continues. I'm not familiar with the V6, does it have a rocker shaft or individual rockers?
Wierd issue, just keep adjusting until it holds doesn't seem right.
flash041
Norm
        Mine ever had a valve get "tight" before the rebuild. Loose but not tight. I have put on about 10k since the rebuild.I am glad it was not a problem that I had to tear it apart again. I can deal with a little adjustment!
I had that issue as well. just have to Adjust them and hope that it sticks.
Louises did the same thing during the Stampede.  I had it readjusted and it is doing it again.  Seems like a common problem, anyone have an idea on how to fix it without doing this every two thousand miles?
PintoMan1
 ;D 8) that great to hear  thanks for the helpfully tip as well!  8)
1973 pinto runabout
flash041
My Pinto had developed a miss. I traced it down to #2 cylinder.The plug and wire checked out good.  I did a compression test and found it had only 80 psi while the other cylinders were 130- 140. I pulled the valve cover and found NO clearence on the exhaust valve! The valve must of seated a bit in after the rebuild.I lossened it up to spec and the engine is smooth again!
