1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
78-80 Windshield
Date: 10/29/2021 03:11 pm
Bell housing
Date: 08/23/2017 05:41 am
1980 PINTO for sale
Date: 06/19/2017 02:51 pm
Date: 09/10/2018 10:41 pm
Date: 02/10/2017 09:30 am
Date: 08/13/2021 10:39 am
nos core support
Date: 01/03/2020 09:39 pm
Date: 08/22/2017 09:21 pm
  • Online today: 1,044
  • Guests: 63
  • Total: 63
Recommendations for new A/C condensor?
Started by popbumper, July 19, 2011, 07:37:20 PM
Gentlemen:
  I bought a new Sanden compressor yesterday that is filled with PAG oil (it looks nearly identical to the SANKYO unit that was installed originally), so I should be good on that account. I am also having new hoses built to the evaporator, and having the expansion valve changed. Only rationale for R134a really was to reduce the cost/availability issues of R12. Maybe I'm overemphasizing that, but everyone seems to think R134a is the best bet.
  Condensor - I definitely need to get a NEW condensor because the old one is so rough, bad hoses, crusty, etc.
  I will contact the outfits suggested.
THANK YOU all for your kind and thorough responses!!!
I've converted several classic cars  from York compressors to Sandin. I never knew anyone but Vintage air had the bolt on conversion for this using the stock york mounting brackets. The Sandin compressor doesn't require as much energy to operate under load as the old Yorks so it frees up a little Horse Power.
I highly suggest Vintage air in San Antonio, TX.
www.vintageair.com
Best of Luck
FrankBoss
Scott Hamilton
The Florida Classic Auto Air OEM division totally rebuilt/redesigned My 72 system- complete rebuilt of every part.. I purchased a used system from another member and had it rebuilt and changed to 134a. I have not installed it yet however so I can't give you any heads up on how it works but was very happy with their service and support. They recommend a Sandin compressor instead of the stock York. They also provided mounting brackets etc...
Norm's right- these guys know air systems.
Tough to guess at this one, I would try these guys. http://www.classicautoair.com/ they seem to be very helpful and hopefuly can help size the condenser for your system.
Good luck with the R-134A conversion I have heard mixed results from this both good and bad, so I decided to keep the R-12. And be sure to remove all the oil, the pre-1985 oil wil not mix well with the R-134a and thus could starve the compressor of oil.  The newer R12 systems had pag oils which worked well enough with R134a and R-12, but the older systems (like in the Pinto) used mineral oil which will not work well with R-134a.  Also do not put in too much oil, less is better in this case and try to keep track of how much oil you have taken out so you can put that amount back and not a drop more. I just rebuilt the wife's air conditioning with R12 and had no cooling because of too much oil, took me a while to troubleshoot that one. After a new compressor, new hose, New TEV, New filter drier, new o-rings and new R-12.  She cooled for a few minutes and then got progressivly warmer.  What happened was the refrigerant would seperate from the oil when the unit was off, so the system would cool for one cycle, then  mix with the excessive amount of oil and not cool.  Just wanted to pass on the fun I had so you don't follow my mess. I did a liquid recovery which pulled out most of the oil, recharged with vapor and problem solved.
Putting the A/C system of my wagon back together; was a dealer installed setup, but have it torn down to clean up and renew/rebuild.
Having new hoses made, changing over to R134A, bought a new compressor.
CAN ANYONE RECOMMEND a good CONDENSOR? A "cross-flow" type was suggested, do not know where to get. Rock Auto does not have these; my dealer installed unit is crusty and nasty, would rather replace altogether.
Thanks!
