Date: 08/01/2018 01:17 pm
Date: 02/14/2018 01:34 am
Date: 05/22/2018 02:27 pm
Date: 10/14/2019 08:24 pm
72' hatchback parts wanted
Date: 08/25/2019 02:57 am
Date: 03/29/2019 07:20 am
1971-73 2.0 motor moiunts
Date: 05/17/2024 09:18 pm
Date: 02/28/2024 02:07 pm
Date: 08/09/2018 07:49 am
  • Online today: 1,473
  • Guests: 1391
  • Total: 1391
Pinto/Shay 1980 Rear end
Started by Brownie, July 12, 2011, 11:15:45 AM
if he hasn't contacted you yet... Fred Morgan his email is spot7768@netzero.net and may be the one to ask, I think he mentioned the other day he has 15 Pintos in the yard and regulary supplies parts to us Pinto Nutz
Brownie
I recently purchased a 1980 Ford Shay.  Mine is the "reproduction" Model A Roadster Pickup.  Yesterday I noticed that the rear driver side tire was wobbling.  I pulled the shaft and noticed that about 1/3 of it was missing.  I expect that the shaft was over heat treated or for some other reason failed.  The shaft has a number "9E8CA" located between the four bolt pattern with a ford insignia molded into the surface.
I am told that Shay used all Ford products and most were the small format Pinto parts.  This is a 17 spline shaft.  Any one know where I can pick up one.  If not how about a line on a rearend.
Edwin L. Petersen
browniepetersen@readytek.net
435 279-6930
