Date: 08/06/2021 02:23 pm
Date: 08/30/2021 03:20 pm
Parts Parts Parts
Date: 09/08/2018 03:13 pm
front end parts
Date: 03/30/2018 12:48 pm
Date: 08/09/2018 07:49 am
Hood Hinge rubber boots
Date: 09/28/2018 05:49 pm
1600 CC WATER PUMP
Date: 06/02/2018 09:13 am
Date: 02/10/2017 09:30 am
1974 Wiring diagram free
Date: 10/27/2019 06:56 pm
  • Online today: 116
  • Guests: 106
  • Total: 106
Exhaust differences in 74-78 Pintos w/2.3 4 cylinder
Started by r4pinto, July 03, 2011, 11:02:49 PM
My manifold is good & I got a replacement downpipe from quickrick back in 06 but I was trying to find out if there was one in a slightly larger pipe than what I got. From what everyone said it seems they were just the one size so I will prolly have to see about getting a reducer or something to make it work.
do you need an exhaust manifold and down pipe to the converter?
Yeah, that's what I was afraid of. It hasn't been right since the idiot tow truck driver from west virginia ripped it off in 2006 & maintained 100% deniablility. Oh well, it happens. I'll figure it out one way or the other.
matt, converters started in 76 on pintos.i would think the 2.3 peice from exhaust to converter non converter would be the same. when i looked for a converter fo mine a few years a go i could not find one for a 76 or earlyer though,so something is different. all i could find for 76 was a universal for any car. as a result mine is now hollow.in my area ther is an exhaust shop tht  can  custom make any part and is usualy cheaper than buying the part  and doing it your  self.
I know what you mean, Matt. My 78 needs a new pipe from the cat back to the muffler. Muffler is good but the cat was hollowed out some time in it's past. My down pipe is larger than the cat to muffler though, I am positive of that.
Quote from: 77pintocw on July 04, 2011, 07:32:57 AM
Heyr4pinto:
Attached is a figure showing the exhaust system and part numbers for
a 1977 Sedan with the 2.3 engine and w/o the catalytic convertor.
Hope this helps.
77pintocw
Hmmmm... That does help a little. It sucks that the parts aren't readily available so I guess I will have to make something work lol.
I think the catalytic converter came along with the requirement for unleaded fuel, which went into effect with 1975 model cars.
77pintocw
Heyr4pinto:
Hope this helps.
77pintocw
1977, Pinto Cruising Wagon, White with Blue Graphics
if i'm not mistaken; i believe federal laws required them on most passenger cars starting in 1974
Got a question regarding the differences of the exhaust systems on the Pintos on the 2.3 4 cylinder sedan/hatchback models. I know the 77s had a catalytic convertor but did the years prior to that? The reason I am asking is I have a 77 Pinto that I am having to fix the exhaust but it has no convertor. Is the downpipe from the exhaust manifold on pre-convertor cars a different size? Trying to figure out what I can do to fix the car so the exhaust does not fall off the car again.
Thanks for any info!
