Date: 07/30/2018 04:32 pm
Date: 10/15/2017 10:03 am
Date: 10/24/2019 01:45 pm
A.c. alternator hrackets
Date: 09/03/2017 12:11 pm
Oddsnends
Date: 12/20/2016 10:52 am
Date: 08/01/2023 06:53 pm
Mustang II V8 swap parts
Date: 03/26/2017 02:25 pm
Date: 03/17/2019 10:15 pm
Date: 04/12/2017 08:15 am
  • Total Topics: 16,268
  • Online today: 150
New car !
Started by Reeves1, June 30, 2011, 07:47:57 AM
Looking good and a tight fit, if only they made the engine compartment just two inch,s wider and a inch or so longer , it make me think they done that on propose  :o
Finally ! Should be done in the next few days.....then they will be sent for ceramic coating.
2" tubes to a 3 1/2" collector.
Seems to be worth the wait Reeves and you have your blue one to keep you busy :)
That picture looks like Idaho :)
Yesterday.....not likely to see it for a month. Maybe more (for a number of reasons).
After the Headers are done they will be removed & sent to the city for ceramic coating, inside & out.
Be lucky to be able to start by xmas.
76hotrodpinto
I would need anti-viagra.
Hope when you get the car back you have someone to drive you to the hospital the have that huge smile surgically removed  ;D
Good news - got a text last night - welder ready to build my Headers !  ;D
Since I have the blue car up on jack stands, cut apart & no front suspension , it means I will haul it over (20 - 30 minutes away) Thursday morning !
Read the text, hands started to shake & big grin on my face !  ;D
Quote from: 65ShelbyClone on July 01, 2015, 09:03:58 PM
Sounds more like the problem is from not running a stick.  ;)
Randy has been racing BOSS 302s for 40+ years. One of the rare ones to have them figured out.
Plus it may be due to the class he wants to run in ?
Quote from: Reeves1 on June 28, 2015, 05:41:58 AM
Problem with an auto in a BOSS is the way the engine is built. Not much in the bottom RPMs. Monster ports like the mid to high end.
Bud - how long are your collectors ? (need longer collectors when using an auto)
I think they are 20" on Randy's car, with 2" tubes.
79prostreet
I'm running a c4, we'll see how it works. Guy that built it said it should work fine and withstand my TQ/HP.
79prostreet
Only guy I know running an auto behind a B2 engine is Randy Gillis, in his 68 Shelby.
He has it well sorted out & works well.
https://www.youtube.com/watch?v=CVIWbf60dpc
HOSS429
the second V8 pinto i ever built was a  full framed Bogus BOSS 302 .. .. a 289 with 351 4 barrel heads  modified to fit and a genuine boss 302 intake and some other BOSS parts .. i tried to run an automatic trans in it ... big time fail ...i had to back up and read your build thread from the start to make sure you was`nt trying to run an automatic ..i later built a 460 for the pinto but could not cure a bump steer problem .. that car is still around somewhere .. i gotta find it ..
Engine bay done.
Rad hoses not clamped to rad as it will be removed for the Header build (one day).
Note the electric fan on the inside. By using a short water pump & single pulleys there is just enough room, by also using semi solid motor mounts.
Quote from: 76hotrodpinto on June 02, 2015, 09:28:10 AM
What about a filter/housing with a smaller diameter that will clear the scoop base lip? From the pic, it looks like you could get away with that. Or maybe build a filter housing into the scoop, and use a flange on the top of the carb. with a flex seal to meet with the hood closed. Kinda' shaker style. However you go, I wish I had the same problem!
Looking at that setup, I think we all wish we had that problem LOL :P
76hotrodpinto
Time to make a filter base it appears.
79prostreet
You could move the motor forward!!   Just kidding my friend.  Off-set air cleaner base maybe?
79prostreet
You'll figure it out :) Just more height :)
What I'm head scratching about now......sometimes my thinker works slow.
Hope you post it firing up :D
Very little left to do now.
Tying up a few small things.
I have the lower rad hose figured out & it will be done next week.
I primed the oil - with the new filter & 90 degree piece, no oil was it them.....which also tested the new copper tube to the pressure gage.
Going to check rockers. Have not done so after the dyno run.
I took the snorkel off the hood scoop. Set the hood on the car.....yup, needs mods.
I raised the engine & moved it back as far as I could. Along with the much higher than stock intake, the Bud Moore Mini Plenum, I need to replace the 2" high snorkel with a 3" one. Which I've seen on the Jegs site.
It will have to be modified from a slope at the back to straight up, for air filter clearance.
Need to figure out a front drive shaft loop....
Last things will be a new drive shaft & Headers........after I get back to work. Money is getting low....
Quote from: Reeves1 on May 24, 2015, 10:16:08 PM
Thanks !
I'm happy with how it's coming along (except too slow) !
While brushing my teeth this morning my "brain" came up with a design for the lower rad hose.
Ordered the bends from Summit today !
Canada has a big time lack of good parts !
You should be :) I hope my Pinto (one only getting a turbo and the other EFI) looks as good as your work!
We do here also. Ordered Raybestos parts and they were made in China :(
Thanks !
Quote from: 74 PintoWagon on May 24, 2015, 08:21:51 AM
Whatever makes things easier, still looks good..
Freakin' looks awesome!
