Date: 01/28/2019 05:15 pm
Date: 07/04/2017 03:26 pm
parting out 1975 & 80 pintos
Date: 04/28/2018 04:12 pm
71-73 Rear valance panel
Date: 01/14/2021 06:54 pm
Parts for 74 Squire Wagon
Date: 09/16/2019 07:35 pm
Date: 09/17/2024 12:35 pm
Interior Parts
Date: 08/07/2017 03:59 pm
Date: 10/24/2019 01:43 pm
1974 Wiring diagram free
Date: 10/27/2019 06:56 pm
  • Total Topics: 16,268
  • Online today: 208
  • Guests: 191
  • Total: 191
New car !
Started by Reeves1, June 30, 2011, 07:47:57 AM
FYI
Stopped in at the (new) engine builder in Edmonton AB.
Wish I had heard about him before sending the engine to CA.
New parts list:
Oil pump
Timing gears and chain
All new bearings
New rod bolts
Crank studs
Line bore (was .006 past max allowable)
Bore cylinders to .030
Pistons & rings
Cam, lifters, push rods
Rockers
Springs keepers etc
Valves
Head work
(what did I miss ?)
Balance & Blue Print
Shop builds everything from rail engines to stock. Has for a long time & has a very good rep.
Cost is much less than the CA build @ $6700.00 (ish)
Dyno day is another $800.00
There will be other costs.
Will not know which carb I'll be using till the dyno work.
I have four intakes.
I'll be using the Mini Plenum
Spares are :
OEM
Weiand single 4 Tunnel Ram with NOS fittings.
Weiand 2 x 4 Tunnel Ram. This one is NEW, never used.
Engine is being built for race gas (could mix if I wanted).
Not built for NOS.
Car will be scary enough without that stuff.....at least for me.
Completion date end of April (or early May).
Quote from: Pinto5.0 on March 28, 2014, 09:21:49 AM
My scars from wrenching read like a roadmap
I hear that, and along with header burns, lol.
Quote from: 74 PintoWagon on March 28, 2014, 07:58:47 AM
I hate removing skin, LOL.. ;D ;D
The way I put engines/trans into these, I have not had any troubles, even though I do it all by myself.
Done it so many times I could likely do it in the dark ..... besides.....skin grows (mostly) back  ;D
You need to make the tunnel removable to get at some of those bolts. You must have the patience of Job to wrench in tight spaces because I throw wrenches frequently when I'm jammed tight in a small area LOL.
Made a set of templates. Bigger one is for the left (drivers) side.
May trim some more off of them ?
To these will be welded angle iron. One on the frame rail.
I have poly pads (same as I used for the engine mounts).
They'll bolt to the back of the Quick Time bell.
Since my B2 is away getting yet another re-build....
I have a spare 302w roller block. Put it in the car so I can figure out the mid mounts.
Still have not found a plate that I like.
I may have the back plate for the Quick Time bell re-made to my specs.
Or...I may make a bracket for each side of my own design.
Got to think on it......
A little progress , is still progress , right ?
Made four Mini Plenum gaskets. Two are 1/16" two are 1/32".
Research showed 1/16" what people were using. Seems thick.....
Cut some plexi to keep them as made.
Top right 2.5" hole is where the main wire harness will go through the fire wall.
I'll cut two 3" aluminum plates , with a center bolt (small one) & seal up the original hole.
Doing it this way so I do not have to pull the stuff off of the inside , to weld it up.
(brake lines will be re-located in the future)
Was looking at a number of them this morning.
Was also looking at my car yesterday. The bell & trans still sits in the car.
I have a couple 302w blocks sitting around to make sure everything lines up.
B2 engine will not be back home till late March or April.
Looks to me I could make some 1/4" brackets that can bolt on behind the bell flange. I can make it/them so at least 3 bolts go through them.
Have to think on this more.....
Could only find a 1/8" plate on the S&W site.
I'll measure my back plate today.
79prostreet
Reeves1, the plate I used came from S&W race cars it's 3/32 thick steel and goes between the trans & block.
79prostreet
Thanks for the picture.
Did a google search on mid plates. Most are too thick & aluminum ?
Is/are they bolted outside of the bell, or replace the back plate ?
Best ones replace the back plate ? I have a Quicktime bell. Steel back plate.
My Super T-10 cannot be moved back at all. I have to use an extended pilot bushing as it is.
79prostreet
Hey, no problem. I think once you get started you'll find it to be no big deal. By the time I got done cutting on mine not much left. The picture shows it in the back area to a tab on the frame. Bud
79prostreet
79prostreet
Hey, no problem. I think you'll find not to be a big deal once you get started. By the time I was done with mine there was'nt much left.
79prostreet
Quote from: 79prostreet on April 10, 2013, 09:05:38 PM
Do you plan on a mid plate?
The more I look at the car & think on it.......I like this idea.
Thanks for creating more work for me !  ::)
;D
I sent the engine into the city (Edmonton) for a full inspection.
Wrong crank/rod bearings. The rods were binding on the outsides of the bearings. (pics of this & more will be taken after the junk parts are back home)
Wrong rod bolts - they are the ARP 8740 & no builder in his right mind uses anymore.
Was told it looks like the bearings were replaced after the dyno runs.
Rods will go through a more detailed inspection to see if they can be re-used.
Crank (so far) looks OK - more detailed inspection will be done.
Although I was charged for .030 over pistons to be turned to fit .020 bore.....they were not done. They are real .020 over pistons.
But the compression in not 11:1 as told. Worked out to 10.35:1
Bottom timing chain gear damaged (didn't look at the top one or chain)
Cam may have damage....it looked that way at home before sending into the city.
Doesn't matter - wrong one for this engine anyway.
One set of lifters backwards to the others.
Left head gasket on backwards.
This caused a heat problem & damaged the exhaust guides.
He put the cheap stainless valves in - two exhaust valves are bent.
Head is OK though.
New parts (so far) needed:
Rod bolts Maybe rods)
New .030 over pistons (to get compression up)
Rings
all bearings, seals & gaskets
New custom grind cam, solid roller.
Push rods
Lifters
Valves , springs etc
New timing chain & gears
Oil pump
New intake will be a Mini Plenum & new carb
What did I miss ?
PS: another guy had his B2 engine built at the same time as mine. Built in the same way. He was maybe 5 minutes from home & KNOCK KNOCK KNOCK !
He babied it home & is sending that engine back.
Great engine builder, huh !
Called this morning.....lots left to check.....but lots of bad news.
It may be a week or so before I post all the info.
I'll pick the engine up on the 21st (ish) , when headed home for the season break  :'(
That sucks, sorry to hear that.. :(
Sad day.... re-crate the engine to send it away for tear down and inspection.
Block will be magged, soniced and checked for core shift. Plus a detailed inspection.
Same for heads, plus flow check each port.
So far, new parts needed:
All gaskets
Seals
Crank
All bearings
Cam
Lifters
Push rods
Rods bolts ( has the cheap 8740 ARP bolts)
Rockers
Springs retainers etc
Likely valves , as they may be the cheap stainless ones
Oil pump
If the block fails inspection, maybe a whole new engine.
Even the left head gasket is on backwards.
Don't send anything to Mascar in Ca......
Scroll back up & see the hole in the inner fender. Same on both sides. Back 2 tubes on each side go through there.
Front 2 on each side go slightly forward, down and under the cross member.
Likely the same as the old Hooker swap headers went.
Those are strange looking headers.
Duh !
I raised the engine due to the Milodon pan. Headers will not fit without lowering the rack. Plus the motor mounts I made are in the way.
Gotta think on what to do......
On the way home from MT I stopped in the town where the original headers for my car (when it had the original B2 engine) have been sitting for several years.
Last time I tried to buy them, the guy wanted more than new price.
This time he took $150.00 for them.....a few dents to fix & maybe new ceramic coating, down the road.
I'll clean off the outside of the inner fender. Then "tap" the spot welds to make them flush on the outside, to help prevent grinding/sanding the metal too thin or through.
Then grind/sand the spot welds & make it look like the support was never there.
I'll sand blast to completely remove the rust, before any primer/paint.
Did this for 2 main reasons. One, the rust. Second, I'll need the room for when I route the new heater lines.
Had some time to do a bit of work.
Using a spot weld drill it I drilled the battery support.
I could see some rust dust "leaking" from under it.
Drilled & ready to move.
What is under it.
Left click first picture. It will/should pop up bigger. Then use the next button to see the rest. Keep track of pics if you have any you want more info on.
I never started this engine.
Going for (another) re-build this winter.
Finally got into the motor some more.
After getting my trans & V-Gate in-line shifter worked out, I left the car sitting.
Pulled the engine for a closer look.
I didn't pull the cam, but can see scoring on the front lobe. No pic of it.
I pulled one rod cap. Gave up pulling others, as it is a complete waste of time.
Looks like I will try to use/salvage: bare block, bare heads, timing cover & dip stick/tube. Dampener, oil pan & pick up.
I have a Mini Plenum I'll be using on the next build (found a good guy in Ont Canada).
New carb. I'll see if the dist can be salvaged, depends on what he did to set the gear on it.
http://smg.photobucket.com/user/DerrickJB/library/Bad%20Engine?sort=3&page=1
Left click the first one. It will (should) pop up bigger. Then use the next button to see the rest.
Reason for sending this is, thought you may want to know.
Derrick
New front brakes.
http://www.summitracing.com/int/parts/wil-140-11017/overview/
Was going to order them from that place, but after working out USD/CAD exchange, taxes, duty.....was cheaper to buy right here in Edmonton.
ETPinto
I feel its solidly established that this car is mechanically awesome.  Therefore it is my desire to point out that the interior, white on black, gave me a woody.  Those white door panels/arm rests and seats with black cockpit are sweeeet!
