Date: 06/28/2019 09:14 pm
Date: 10/05/2017 02:26 pm
Seeking parts
Date: 10/18/2020 10:35 am
Date: 10/02/2017 02:16 pm
Date: 12/10/2016 04:11 pm
oldskool787
Date: 02/12/2017 12:42 pm
79 pinto driveshaft
Date: 08/18/2018 02:03 pm
Date: 02/14/2018 01:34 am
73 rear hatchback glass
Date: 07/06/2017 11:33 am
  • Total Topics: 16,268
  • Online today: 208
  • Guests: 184
  • Total: 184
New car !
Started by Reeves1, June 30, 2011, 07:47:57 AM
GremenLogan1
I agree we must take prior concern on the selection and it's conditions too...I have almost check all of them :)
Find
body kit
jeremysdad
Quote from: Reeves1 on September 01, 2013, 06:49:39 AM
"Worked" on the car yesterday........was walking by it to the shop fridge & spotted 3 rocks in the FL tire......again. They have been bugging me for months & always "too busy" to remove them.
Guess they finally bugged me too much, so took them out.
Building a 20' x 15' storage building. Need it to store car parts and tons of other stuff in the shop.
That alone was good for at least a .1 second drop in ET, right?
On a serious note...it amazes me that the 'trained monkeys' at most major tire retailers don't realize that they should remove as many rocks/other stowaways as possible before balancing a tire. Hey...it's a rock. If it finally dislodges at freeway speed, there went your balance. On the flip side...stupid rocks! :) lol
Haven't had the car out with the T-10. Engine builder took me to the cleaners & sent it back ready to blow up. Have to get it re-built......again.
After I get the new 20' x 15' storage barn built & loads of stuff moved out of the shop, I'll get back to work on the cars.
and
Find out if the U - joint can be used.
fozzy
Quote from: Reeves1 on April 27, 2013, 10:21:57 AM
The Super T-10 is a better trans than the Ford RUG trans. Tougher.
Plus I like shifting !
Top end/cruising speed is better than a 3 auto.
How is the top end/cruising speed better with a T-10 than with an auto?
Did you ever come up with a solution to removing the cable steering and getting a universal joint to fit the steering rack?
Fozzy
Making it stronger......  ;D
I prefer rowing gears myself. Unless I'm into drag racing for the money it's too boring dropping it in drive.
FairWarning1990
I was with you on every single choice until the transmission (if you held a gun to my head, that's the only negative I can think of here). A little too much unnecessary work for my tastes. Sit back and let the tranny do it's job, man!  I'm sitting here like the voice in the wilderness screaming "C4 BABY"!
Duh ! Couldn't stop myself ! Got it for $157.37
Drilled for NOS. Can plug holes or use.
Using would mean a bit of difference in the new engine build though.
What can I say..... I like Ford blue  ;D
Will not be using a back plate. I have a couple ideas to make the ones I made work OK. I hope....
Got the shifter figured out & adjusted on the Super T-10. Ended up with extra rods & a few other parts. Had to use the shifter arm (trans) for reverse from a Hurst shifter set up. The handle for the Long Shifter is small & I have big hands, so used a new Hurst shifter handle. Has the button for the line lock.
Now to clean up the trans & paint.
I picked up a sand blaster , but it plugs up fast. Glass that came with it is too big. I think. Going to pick smaller sand up, to do the trans mount & paint it as well.
79prostreet
Reeves, I don't have a real good picture of my set up but I'll post what I have. The mid plate is at most 1/8 , so motor ahead 1/8 or tranny back 1/8 not to big of a deal for the added support it gives. Bud
79prostreet
Quote from: Pinto5.0 on April 10, 2013, 07:10:28 PM
I'm not too sure horizontal mounts on a flat plane are gonna handle the stress.
That was a question in my head as well. I was thinking a flat 1/4" bar welded onto the left plate up to a header bolt may tie it in better ? To a head bolt would be better, depending on where the header tube will be ?
QuoteDo you plan on a mid plate?
Was not planning on one. I'd have to move the engine forward to do so.
79prostreet
79prostreet
Built (finally) motor mounts.
Plates are about 5 1/2" wide.
Angle iron will be welded to the frame rails after the pinion angle is checked/adjusted at the trans mount.
Pads are two firm ones & are 1/2" thick, on each side.
The motor pedestal bolts are 7/16" & was wondering if there is any reason they cannot be drilled out & tapped for 1/2" bolts.
To me, that is the weak point.
There will be a safety cable from the front of the engine to the frame, left side.
There are 10s of thousands of ways to make motor mounts. Thought this easy & simple way was the way to go for my application.
Plates off the engine are 3/8" thick. Angle iron is 2" & 1/4" thick. 1/2" bolts.
I'll use blue lock tight when the final installation is done.All bolts are grade 8.
Part of the reason was to make the header build a bit more simple. There will be little movement of the engine, so clearance for this will not be much of an issue. If you see flaws or weak points, let me know your thoughts.
I still have grinding / trim work to do later. I have a small sand blaster to clean up the parts before painting.
Quote from: Reeves1 on March 23, 2013, 03:28:16 PM
Seems every time I'm home on days of it gets more torn down. I look forward to the day it starts going in the other direction !
i feel ya on that one..... just yanked the engine and tranny for  i think the 6th time now on my red pinto....
Ignore the wire mess. It will all be done much better than what was there to begin with !
Had a couple days off so started on fitting the shifter.
It is a shifter by Long Shifters. In line.
I still have some trimming to do. Ran out of time.
Note how it is line with a persons right shoulder.
Also note the rust where a persons feet sit. It is light though. I'll clean this up & use POR 15 to make nice. Will also use a new style sound deadner , that I've sen people on this forum use. The "fuzzy" stuff (factory) will get tossed.
entropy
This car is going to be absolutey incredible. Hell...this car *is* incredible.   I'll enjoy watching the progress...
1972 Hoonabout
SBF swap
-308 cid
-CNC ported Brodix heads
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
New (to me) intake.
Long time no post !
My axles....
Talk to Norman Bagi about thelouvers & spoiler. He did that with his already so he should know which ones will work. I think he made his louvers from a hatch set if I'm not mistaken.
Little extra time off today...
Found these pics...
Thoughts.... keep my hood scoop. Hot pants kit from Map351. Whimbleton White with the black (reflective like B2s).
Looks good, in my head. Thoughts ?
Would also need to track down the rear louvers (sp ?) & spoiler.
Can't beat that. At least it was complete & you don't need to hunt down more parts.
Nope. Good deal.
I called the guy that is going to build my B2 headers. Asked if he was to copy the set of black headers, how much. He said about $1500.00.
So when this is taken into account, I got a smoke'n deal @ $700.00 + shipping, for the whole kit.
Sometime next summer I'll be on the look out for a 71......or a newer version like a 74 ^ for a light weight build.
Cool, glad I could help. Did you get raped?  :'(
What they are, is SOLD !  ;D
Yup, bought the kit !
NOS, never used. All parts are there. They are no longer made.
Kit is for 289w , 302w and 351w.
That makes two sets of headers of this kind I now have. No other parts came with this set.
I'll have the above 2 sets ceramic coated, inside and out, when the ones for my B2 are built in Dec.
