Date: 05/03/2024 05:37 am
2.3 pinto carb
Date: 08/18/2018 02:07 pm
74 4 spd and rear axle
Date: 09/26/2018 03:51 pm
Date: 09/12/2018 04:07 pm
sport steering wheeel
Date: 10/01/2020 10:58 pm
Need Interior Panels
Date: 07/09/2018 04:59 pm
rear hatch back louvers
Date: 04/18/2017 12:44 pm
77 Cruising Wagon Front Seats
Date: 04/12/2017 12:37 pm
Date: 04/07/2021 06:12 pm
  • Total Topics: 16,268
  • Online today: 232
  • Guests: 164
  • Total: 164
New car !
Started by Reeves1, June 30, 2011, 07:47:57 AM
Guy to the west of me had a 351 C built by the same builder. He had been fighting an over heating problem for a while..... pulled the heads & discovered it had the wrong head gaskets.
Mine has not over heated during tests, in my shop. However, I am a worry sort of guy.....plus I need to know the head gasket compression thickness.
No OEM BOSS 302 gaskets can be purchased anymore......
Guy I'll be getting the cam from will also supply new head gaskets with the "kit".
I'm changing the roller rockers as well.....
Could use a dial indicator instead of yanking the heads.
Forgot to take pictures....
Water pump back on.
Didn't fill with coolant. May be pulling the heads this winter to clay the pistons (last engine builder never did give me a build sheet).
Reason for clay ? Likely going to change the cam from 351w firing order , back to 302.
Also been told by a very good B2 engine guy I left as much as 60 HP on the table.
Car doesn't need more HP, but wanted a little more HP at higher RPM.
Header builder never did show up. I may try my hand on fixing the back tubes myself...... this winter. Another year/driving season lost due to others poor workmanship. Not happy.......
Coolant leak.... pulled the short water pump off. With this pump, you have no bolt in the corner of each water port (I'll post pics later). It leaked past this.
Ordering the gasket that goes between the pump 7 back plate today. I have spares for the front.
Also going to order Permatex thermostat/water pump sealant.
I also changed the front (flex) brake lines/brackets, so need to bleed them again.
If someone has 30k kicking around....... and wants this car to finish....
Header builder is supposed to be here today to look ....... he thinks an easy fix ! LOL !
Back two tubes need to be re-made, on the left (7&8)
Third back on right (#3) has to be re-made ..... and maybe #4.
We shall see.....
I cannot haul the car to his place. Put the Wilwood brake / hub kit on & do not have the new wheels & tires yet.
Still pissed about the Headers not being right - if they had been, I'd have been able to drive it this year.
If someone offered me 30k (or more ?) it would be gone in a heart beat !
More excited about getting the blue one done.......
Quote from: 74 PintoWagon on June 09, 2016, 07:32:05 AM
You're gonna sell it? ??? :o :o :o :o :o
That totally took me by surprise too!!!
Dwayne :)
You're gonna sell it???? :o :o :o :o :o
Anyone want this car ? 30k !
Coolant leak......have to pull the water pump.
(pics later)
Got the stuff installed.
Had to remove the L brackets off of the frame & go a different way with the flex lines. May make yet another support bracket, that will mount to the spindle - have to check (again) stop to stop & see if the line will permit this.
Bleed the system out of the DOT 4 fluid & put all new Wilwood 600 degree fluid in.
I'll then do a final system bleed all round.
The caliper bolts that come with the kit are too short. I picked up new gr 8 bolts 1 1/2" and they are too long. Will make them right today (shorten).
Looks great!!!
Dwayne :)
Shouldn't have any trouble stopping with that setup..
I also had to replace the 15 lb rad caps I had gotten from Mopac.
The rubber seal in the upper part was not wide enough to seal properly & would leak a bit when shut off & cooling.
New ones from "Be Cool", makers of the rad have a wider seal & are 13 lbs.
So.......I have to flash it up & get to running temp for testing again........ oh darn  ;D
About the mpg.......it's going to be a fuel hog ! Started 3 - 4 times & burned (about) 4 gal !
(about $120.00 worth)
Test fit the left side. Only used a couple bolts in each piece ( a little more than finger tight). Have to pick up some ordered stuff this morning to finish assembly. Proper bearing grease, Loctite 271 & Wilwood high temp (600 degrees) brake fluid.....
76hotrodpinto
I don't have any info for the early models, but for the 74 and up, the tubular control arms are usually set up to run without the struts(coil and spring, bags or coil overs). They are also available in some altered lengths, as well as adjustable ones. If any of this helps.
Bud - do you still use strut arms ?
Your car is newer as well - they make them for 72s ?
Hate to change them - all new suspension parts.
Tubes for # 3 & 7 need to be altered (or re-made) & tube for #8 has to be re-made from the head down.
Wrong angles, interference with frame rails & more.
I had them bolted on & started.... but blew out the gasket at #8 (back left) & there is no way to make them work.
Numbers 3&7 will just not work at all , due to the strut arms. First bump will flatten them & maybe bend the strut arms ..... and I do not think new ones can be had ?
Contacting the header builder in AM.......
79prostreet
Derrick, would tubular  A arms give you the room you need?
79prostreet
Bummer, looks like some re fabbing is in order there.
I have no idea what he was thinking.....  :'(
Will not be driving it any time soon.... welder is also a pipe line welder & farmer - his busy season right now.
I know another guy that may be able to help. Will contact him later today ?
Pipe for #3 cyl, right side will hit the strut arm on the first bump......same for the left side.
(still messing with left side to figure out #8 pipe/flange)
There's a message there when the "Honey-Do" list comes out, better hurry up, LOL...
Might be a short week ! LOL
Have much to do & the wife keeps pointing out her "Honey Do" list on top of it all !
Got the right side clearance done.......except I'm wondering if the Header builder made allowances for the swing arms and strut arm to move.....
Headers are loosely bolted back in. Have to tighten & put the motor mount back in.
Then start on the left side......and figure out why #8 doesn't want to seal.
That's gonna be a long week, lol..
Did you make a appoint with the hospital for the next day to get the smile surgery removed ,  ;D
Back left (#8) header gasket blow out. Removed Headers & checked flange - ceramic coating un-leveled it. Bottom corner was not straight - file smooth & the coating is still on, so they had it too thick.
New gasket & sealant - done. (should have checked after coating - DUH !)
Taking the right side off to do the same & clearance the frame some.
Then install the new Wilwood brake/hub kit & get new tires/rims.
Front alignment booked for next Wed.
Not putting fenders back on till that is done - so I'll take some weights to simulate front parts.
New windshield installed same day.
I let the registration & insurance lapse - shouldn't have ! I now have to get another safety done......
Should be able to drive it a week from now ?
Street / strip.
With 12:1 compression I'm burning C111 fuel.......at $150.00 a 5 gal pail .........not driving far ! LOL !
(cheaper if I buy a 45 gal drum)
Guessing +/- 8 MPG ?  ;D
76hotrodpinto
Quote from: dick1172762 on April 25, 2016, 11:15:47 AM
    NITRO'S better
I like to smell nitro too. Waa waa waa waa...
So is this a street car or a track car? Would be one crazy grocery getter!
My camera with a towel on it, outside the shop 20'
Quote from: 76hotrodpinto on April 25, 2016, 09:47:19 AM
Sounds bad A$$! I would love to see another video, where we can see the beast bounce around with that lumpy cam! Great Job.
Still lots to do (plus $) before I can drive it.......going to try hard to do so though & soon !
Wife took another short video from closer today. Calm day.
I also took one with my camera.......loading to PB now.....
