  • Total Topics: 16,268
  • Online today: 349
New car !
Started by Reeves1, June 30, 2011, 07:47:57 AM
Started an account with IMGUR.... test.
Before.
After
Got the right side done but cannot post pictures. P bucket not working the last couple days. Will post if it is ever fixed.....
#8 pipe on the right done...... one left !
Going well..... except slow. Only working on them a couple hours a day.
Having an acreage means lots of outside work......
Before - was no room for the upper control arm & strut arm to move upwards.
After _ I have to tighten the strut arm & this will give even more room, for the strut arm to move up. I think it's all good now. Tight space for 2" tubes. They are just tacked together & needs welding up. They are off the car now. Also re-coating.....
Start the right side tomorrow......
Mods to left side will be done today.
Then remove & weld the seams - just tacked together now (cannot weld in place - no room).
Got one of 4 tubes done.
Lots of head scratching to do this !
J tubes came in yesterday.
Should be starting changes today..... ?
Money must be tight for everyone.....not one question.
Going to order up some mandrel bends & fix the rear header tubes & get this thing on the road.
Car is for sale. Will separate the engine if you want just the car / engine.
Body , thinking 8k ?
Engine 15k
PM your number to talk ?
Xmas break....
Fully installed the Wilwood brake kit. Not sure if I'll leave it on , for a number of reasons. I'll try & post info later on them.
Pulled the back 2 header tubes off of each side. Head scratching about how to re-build them..... or scrap the whole set & have new ones made.
2016 being a bad earning year, other parts have not been ordered. Yet.
Need new valve springs & rockers, then the engine will be done & good to 9k RPM without any issues.
This will also bump the HP (with other changes I've done) to about 550 + HP.
Don't know what went wrong. Not working for me as well......
Turned down the block. Too much money.
Turn your speakers up.......
Just distilled water in it right now.
Since winter temps are finally on the way, I'll fire it up again & drain when cold.
Afraid of the heat going out when I'm away , then.....
More news.... when I sent my engine to CA for that (piss-poor) re-build, I "allowed" the guy to talk me out of my block. He said it was/is a date match to some 70 cars (Mustangs). (1970 May 12)
He replaced it with a newer one. What he didn't tell me was it isn't as nice / pristine.
Yesterday I spotted an add for 3 B2 blocks...... and one is my old one !
Don't know how, but I'm going to try & get it back !
Quote from: dick1172762 on November 03, 2016, 01:30:17 PM
It smell's like money ($$$$). Lots of money.
About $30.00 a gallon !
I'll use it up starting the car a few more times before spring. Then fresh stuff.
Ain't that the truth, lol..
Gotta love the smell of race gas. :D
Just because I can......  ;D
Started the engine a couple days ago.
Shop still smells like race gas ! LOL
This time I was "smart" enough to wear a respirator & ear plugs  ;D
Big shop door sealed for the winter, so just a back window & man door open, with a big fan for moving air.
Letting header builder know I'm home , so MAYBE he can fix them........still no front wheels so cannot move it.
Work very slow this year.
Well, something like this is more or less whatever someone is willing to pay for it, but there's always that "someone" out there that just can't live without it, that's the one you need to find. But you came this far with it you shouldn't give up on it now and finish it the way you want it.. Just MWO...
What do you think the car would go for ?
In USD / CDN ?
To finish so it can be driven.....
Headers. Fix the back tubes or start from scratch.
Front wheels/tire.
Front alignment.
Safety check, insurance.
Drive it.
To finish (like I want).
Body work.... hood needs work due to damage from last owner & me changing engine up etc.
Right door has a small area to cut out & replace with new metal.
Paint flaws , so all new paint.
Diff floated & wheely bars.
May need a new drive shaft.
Should have a better cage.
Weak point..... Super T-10 has the small input/output. Although it worked fine with a well built B2 engine in a 67 Cougar.
So close, yet so far.......
Yeah, stuff adds up quick..
Well built / new B2 (real) engine = 16k + then add on all the stuff that bolts to it.
Intake is a Bud Moore mini plenum - goes for 3k to 4.5k.
Super T10 that is like new, the inline shifter by Long Shifters - about 700 +(for shifter alone)
Narrowed 9" with Mark Williams High Torque axels.
Tubs & tons more.
Rust free (except for a small area on the right door).
Well, you get the gist........it's all been posted here & I'd never hold anything back !
Quote from: Reeves1 on August 15, 2016, 06:31:14 AM
Wonder how many went cross eyed reading the 30k price ?  ;D
Probably quite a few, lol.. ;D
Still have to check ,on an engine like this one , just in case......
Good stud girdle reduce valve adjustments quite a bit.
Gaskets are cheap.
Sort of a pain pulling the top of the mini plenum to re-torque the 4 bolts after a heat cycle though.
Adjusting rockers no big deal. This is not a low maintenance engine anyway, with solid rollers.
Checking adjustment & for broken valve springs is a "normal" thing to do....... often.
It's why I ran the plug wires the way I did.
That makes sense, guess I'd be pulling them too..
