72 Pinto Wagon for sale
Date: 12/31/2017 08:40 pm
Date: 01/04/2017 04:07 am
1978 Squire wagon 6 Cly
Date: 02/16/2020 05:42 pm
Anyone scrapping a 1980
Date: 03/13/2020 08:46 pm
Pinto Parts for sale
Date: 06/19/2017 02:01 pm
1978 RUNABOUT
Date: 04/01/2017 03:18 pm
72' hatchback parts wanted
Date: 08/25/2019 02:57 am
free transmissions
Date: 11/28/2019 10:21 am
convert to stick
Date: 05/19/2018 09:26 pm
  • Online today: 1,555
  • Guests: 1438
  • Total: 1438
New car !
Started by Reeves1, June 30, 2011, 07:47:57 AM
Engine finally found it's way home !
Head scratching on how/what to do about the alt.
I have the short water pump (gives me another inch & a half clearance). But no parts are made to move the alt back, on a BOSS 302.
Ready for shipping home...
FYI..... the engine didn't have a windage tray when on the dyno. With the new Milodon pan & windage tray it will bump the HP up to 483.
If for some reason I want even more, I can change up from the 750 DP to an 850 DP and get over 500 HP out of this build.
The 750 will have better street manners though.
Day early !
I'll quote what builder had to say...plus video link.
quote:
345 Cu. In. pump gas 240 .590 cam Engine. I feel that the most important Dyno numbers are the BMEP,It tells you how efficent the engines is.Reeves ran in the 170s.Modern CHI/ AirFlow Research
head type engines run in those numbers.Very Happy.Mini Plenuim made peak Tq.@5500 423.H.P.@
6500 478 The Stock Intake really runs well.Tq.@4800 403.H.P.@6700 465  E-BOSS Tq@5100 416.
H.P.@6500 473  The E-Boss runs Very close to the Mini Plenuim,and has the best average..The OEM
intake really holds its own,and was the only one that liked to rev.to 7000RPMS and only lost 13HP
to the mini and held its Tq up to the E-Boss!! All Manifolds lost Tq,and gained NO H.P. with 1inch open spacers.E-Boss intake fit best on the engine with the OEM style Felpro1248 gasket. Checkout the videos..Hope this info helps..
Kenny@Mascar
http://s408.photobucket.com/albums/pp166/enny043kenny/REEVES%20345/?action=view&current=MVI_3969.mp4
My engine is on the right. Using an electric water pump on the dyno.
The 2 intakes in front are the E-BOSS on the left & OEM on the right.
Ready to rock !
http://www.milodon.com/oil-pans/street-oil-pans-ford73.asp
Just ordered the above pan, bolts & pick up.
If it doesn't work on the B2 I'll use it on the next build with the 302w.
Dyno runs on Friday !
Going to run with three different intakes.
Mini plenuim,E-Boss and the OEM
intake.
Will post results when done.
Rockers were changed out because the comp cam (stainless) ones had 1.68 ratio.
Blue ones are 1.73.
Engine is getting closer to dyno time. The pan with the "hump" in it was no good for this. The rods were touching the hump. He put another pan on for the dyno run.
Note:
Did not notice till I posted the pics....first pic has a blue rocker. Not mine.
My rockers are a grey/sliver comp cam roller rocker.
He is building 4 B2s at the same time.....
Crank & cam set in & adjusted ring gap.
Machine block for one piece main seal.
Bearing clearance and crank end play set.
MMMMMMMMMMM..............(wipes up drool)
Work on the heads started today.
All new stainless valves & hardened exhaust seats.
Engine has been sent to Mascar in CA for the build. Will be back in May.
Will not be on the road too soon though. Lots of other things need to be finished first. Like headers & body work.
Sold the 2x4 intake.....
Lots to do before it will be driven again.
Have to get a new bell housing & test fit it. New fly wheel & clutch.
Get headers built.
Get engine re-built.
Some body work & paint.
New tires & rims. Rear will be Hoosier Pro Street Radial 29x18.50x15.
New front springs & shocks.
New front brake lines.
New carbs.......
beaner
looks good to me run it ;D
brad :)
Dropped the B2 in today. The carbs in the picture are backwards. Even less room when installed the right way (for SBFs with this intake).
New ones are 3/4" shorter though.
http://performanceparts.com/part/Holley/0-1850C
I had plans to replace them anyway......
Finally got the cam info. Going to have a lumpy idle !
Ford cam # DOZX-6250-B
In/Exh lift 0.589
Duration 324
Scott Hamilton
Quote from: johnbigman2011 on December 27, 2011, 12:43:10 AM
All of them in this post. I can go to other post and see everything fine, but here I get the little white box with the X in it.
John, I'm seeing them fine on this end with firefox, safari and IE9- Sounds like your browser can't load photos from photobucket-- can you go to the direct link provided?
Sweet Pinto by the way- SWEET!
That is weird.... did you right click & choose show picture ?
Might be time for a disk clean up on your computer ?
http://smg.photobucket.com/albums/v140/DerrickJB/My%201972%20Pinto/?start=all
The above link should take you to my photo bucket account. I loaded the original pictures of my car, when it was for sale in MI. Plus a few others. I have more to load over time...
johnbigman2011
John - which pictures can you not see ?
johnbigman2011
Man, I wish I could see the pictures. I looked at the web site and that is one nice ride. Somebody has put allot of work in it. For Sure. Change the subject if you don't mind what do I need to  load on my computer to see the pictures??
Well, the engine is home !
Very pleased with what I found so far (still missing the paper work on the engine).
Getting ready for the new engine.....(BOSS 302 was already taken in AB)
Just one quick measurement one day & it is about 19" - 20" from the inside of the tub to the inside of the lip.
I'll have time this winter to get it all figured out.
Quote from: Reeves1 on August 06, 2011, 05:04:38 AMQuick measurement , looks like I can go 19" - 20" wide on the rear & still be under the car.
Plus a bunch of other changes.....
Leave yourself room for the tire to go up on the quarter panel side when hitting bumps. To keep it low & not hit the quarters usually means tucking the tires 3 or 4 inches behind the wheel lip or jacking the rear sky high so tires dont rub.
Quote from: Pinto Pro on August 06, 2011, 02:08:49 AM
A dual quad Boss 302!! that is pretty sick!!..I'll bet that intake manifold is worth a small fortune.
She ought to run real good!!
It's a 70s Drag Pack engine . Getting it from the fan to trans tail end. Including the oil cooler.
Trans is a B/W T-10 with Hurst shifter.
Going to be a fun car to drive !
I'll be making a bunch of changes. After the engine gets here in Sept or Oct I'll then start the search for new tires & rims. Quick measurement , looks like I can go 19" - 20" wide on the rear & still be under the car.
Pinto Pro
