1978 Squire wagon 6 Cly
Date: 03/08/2021 10:44 am
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
Date: 05/13/2021 05:33 pm
Date: 03/16/2017 10:00 pm
Date: 03/25/2019 09:02 pm
pinto floor mats??
Date: 01/11/2017 07:27 am
Pinto brake booster needed
Date: 05/08/2021 09:00 am
'80 Pinto Wagon
Date: 02/01/2018 05:20 pm
pinto for sale
Date: 09/11/2016 09:47 pm
  • Total Topics: 16,268
  • Online today: 208
  • Guests: 195
  • Total: 195
New car !
Started by Reeves1, June 30, 2011, 07:47:57 AM
Quote from: Reeves1 on October 30, 2012, 09:32:34 AM
Same sort as in that link ?
Good to know you were happy with it !
Yeah, it's the Mr. Gasket version. It takes a bit of getting used to as a street shifter but I never missed a gear even power shifting at 7500 RPM.
I loved my V-gate in my Demon. I put 10K miles on that shifter
jim72
The front air dam that is.
jim72
Has the fabricator put a price to them?
Small world !
Was at work & the co. I work for hired a new welder. Turns out he worked at a place that built all types of race cars.
I asked if he built headers & yup !
Best deal, he actually lives about 20 minutes from me !
As soon as I get my T-10 issue sorted out, the car will be going to his place.
He will be building my wheely bars as well !
Quote from: map351 on September 01, 2012, 01:31:29 PM
He has the first one in the making now, just put on the first pass of gel coat.
Nice.... 8)  I've been wondering if those will fit with a '74-up big bumper. I'd rather run that instead of a Cruisin' Wagon front spoiler on my wagon.
racer99
I got a pm from that guy,he said it
wont be too much longer before
I can buy one.
map351
Quote from: Reeves1 on September 01, 2012, 01:02:20 PM
From what I hear, an awesome guy in PA is now making them !  ;D
73 2.3Turbo Pinto
6S1941 / 289 Slab Side
Pinto FiberGlass
Quote from: map351 on September 01, 2012, 06:41:11 AM
Nice Front Air Dam!
map351
73 2.3Turbo Pinto
Pinto FiberGlass
Lokar bracket much nicer than the Holley bracket....
The more I look at & think about the mounts, the more I do not like them.
I'm going to build new ones.
racer99
Instead of 2 individual spacers,I would
do a 1 piece that would lay on the mount
and  the engine would bolt to it.
Quote from: cannonball on August 06, 2012, 06:17:48 AM
did you ever take this car to the track to see how it performed ?????
When I got the car it had a 302w in it. Drove it maybe 100 miles (at most) to see how it handled etc. All I wanted to know is what I'd change when I put a BOSS 302 in it.
Due to many cost over runs it will not be back on the road this year.
It will be next spring though.
T-10 problem. The pilot shaft is just barely in the bearing. Had plans to re-build the tran anyway. Needs to be (about) 1/2" longer.
New Quicktime bell RM-6063 (black one).
cannonball
Holley throttle plate & Lokar cable.
Not too fussy on the size of the plate. May one day change it.
You'll see that lots of detail work needs to be done in the engine compartment. After the headers are built, it will get done.
Due to the new Milodon pan I had to raise the engine. I was going to cut the frame mounts off & re-locate them. Made spacers instead. Let me know your thoughts ?
Done. I'll likely change the alt to a one wire though. Trying to decide on painting the pump, or leave as is. Picked up all new bolts for the pump today. All taken off, till the engine is in for the last time.
That 1/4" flat bar has been in a parts bin since the 70s ? It was a mirror extension for Ford pick ups !
I'll pick up a new belt this week end & test to see if it pulls the pulley out of line. If so, I have a plan on how to fix it.
Next is the bell so I can figure out how to mount the engine....
postalpony
You make an old man very jealous. You sir are a true craftsman, I enjoy
seeing this kind of craftsmanship, keep up the good work!!
                                 Dick
Now all we do is HAUL!
 :o Very nicely done.
That looks great. I doubt you could tuck it in too much tighter.
I (think) I have the alt brackets figured out. I need to do some cleaning & polishing & paint parts.
Lots of clearance under the hood.
I will raise the motor (and trans) if needed. I'd rather not lower the rack.
May mean I'll need to mod the fire wall more than was done before. No big deal.
Those frame mounts are made in such a way they can be flipped. 4 bolts in each one & welded down front & back. Easy to do.
The QT bell I'll be using has tons of clearance as well. I tried to put the stock bell that was on the 302w. Wouldn't fit, due to the ribs it has.
No ribs on the QT:  http://www.summitracing.com/parts/QTI-RM-6063/
racer99
You have the scoop,looking at the photo I would
mod the frame mount to use the engine mount in the photo.
That is if the QT bell gives you enough clearance to the trans
tunnel and doesnt make the engine/trans angle to bad.
Will the v/cs clear the hood ok?
Engine sitting on the floor was driving me nuts. So I made a spreader bar & put the engine sort of in. You can see I changed the oil pan. This means it will need changes. I do not have the new Quick Time bell here yet. So I do not know if I'll raise the engine an inch & a quarter - or lower the rack. I'll decide when I get the bell. Pan is a half inch off the rack in this position.
