Squire trim
Date: 03/28/2018 10:11 am
Date: 04/25/2017 12:17 pm
Date: 08/09/2018 07:49 am
Date: 12/24/2016 04:13 pm
Automatic transmission
Date: 02/13/2021 02:52 pm
Date: 02/14/2019 06:27 pm
Date: 02/26/2017 03:22 pm
74 pinto
Date: 09/11/2016 06:32 pm
Date: 09/21/2018 11:35 am
  • Online today: 1,044
  • Guests: 85
  • Total: 85
2.3 fuel Pump
Started by flash041, June 27, 2011, 04:21:46 PM
Dave carb pump run 2-4 psi pump normally regulator is not needed. Electrical I use in line fuse and go right to fuse block.  Fred   :)
flash041
I just got a 79 2.3 Pinto going for a new Pinto friend I met a local car show yesterday.Its a rustfree Arizona car he just bought.He put an electric fuel pump in in because the lobe that runs the fuelfump was wore down. First is the shaft availlable new? Second the car would not run with the new inline regulator he bought.It had a 6psi max.The fuel would only dribble out. I took the regulator off and the car ran.What should the psi be for an electric fuel pump? is an inline regulator nesasary? Right now he has a manual switch to turn the pump on and off.If he stays electric, what is the best way to set it up?
