1979 hatch needed
Date: 05/13/2018 08:52 pm
1971 Pinto 5.0L
Date: 12/02/2017 12:23 am
1976 Ford Pinto
Date: 07/16/2019 02:51 am
Date: 07/08/2017 08:53 pm
I need a 1976 hood
Date: 12/19/2016 06:02 pm
Date: 01/04/2017 04:07 am
Date: 10/26/2020 03:24 pm
Wheel cap
Date: 04/25/2022 11:21 pm
Bell housing
Date: 08/23/2017 05:41 am
  • Online today: 288
  • Guests: 228
  • Total: 228
Pinto 78 Project
Started by mrskydog, June 24, 2011, 08:57:14 PM
mrskydog
I have been working on the Pinto most of the day ,I couldnt help but to mount up the Crager SS 13 inch rims with Mickey Thompson 50's :P
Ijust had to see how they looked mounted.
"Living the Dream...Driving Old Fords"
1965 Mustang 2+2 Fastback
1980 Pinto Rallye 32,000 Org.
1972 Maverick Grabber V-8 car
2005 Mustang
mrskydog
Been busy removing old Rustproofing out of the engine compartment to reveal the nice bright Orange paint (Messy) still throwing around Ideas on the interior made a Gauge Cluster today. I just need to decide on using a Ford 8-track or continue to searching for a Nice Craig Power Play Unit? (anyone got one) Big Ford Swap at Columbus Ohio 1 week  :) ant wait.
2005 Mustang
mrskydog
Well I decied to go with a Ford AM/FM 8-Track ...I think? i picked this up it plays great!  But I still am kicking around the Idea of a Craig Power Play Hmmmmm- Got to stay Vintage..  8)
2005 Mustang
mrskydog
Now that I have the Pinto home I am trying to work on it after my Job at leat 30min to 1hr a day M-F. I want to try to get it as far as I can by Spring. I have got it all tuned in and runs great now. I have started to detail the engine compartment,remove all the rustproofing mess and cleaning. Today I pulled the after market radio, and Fit the Center console out of a Must.II fits Nice! I think it wiil work well. I wanted to check fit before pulling interior for Carpet and Clean-up.
more pics...I think I should start a new thred in( My Projects) ,which I will do next time.
2005 Mustang
mrskydog
The Pinto is Home now. I will get it in my Garage, for the winter make over. Complete interior clean up, new carpet Etc. This car takes up slightly less space then my 73 Maverick. Here are a few Pics.....
2005 Mustang
Car looks lost in that big shop !  ;D
mrskydog
Carb is all rebuilt ,runs nice. Got the rear end fluid and new  pinion seal installed. Flushed the P.S unit out New Brakes, all ready to come home for a re-make.new carpet install re dyed panels. Going to turn it into a butterfly by Spring.... ;D
some more Pictures....
2005 Mustang
You will need the pedals and the steering bracket that the pedals connect to. Four bolts on the firewall if I remember correctly, two support rods that go from the firewall to the front dash end of the bracket, and then two more, if I recall correctly, at the front dash end of the bracket itself.
It really isn't hard to remove or install, it's just difficult to get to everything under the dash with the limited clearance, even with the driver seat removed. I pulled one out of a station wagon a couple years ago to make room for cutting the floor pan out.
mrskydog
I also have been thinking about, going to a manual set-up rather that a auto? have many others done this , seems like it would be a rather simple switch.
2005 Mustang
mrskydog
I did end up Tapping out the small Exhaust holes 3/8 ,then installed set screws into the ports worked fine. Looks as if I have to go thru the carb the Idle circuit is acting weird. I need to rebuild it any way. Did frnt and rear complete brakes all done. With the power Disc brakes and power steering its almost over kill. :D
I took it in to the shop..I have worked here in Michigan at a Ford dealer for over 25yrs ,got the carb off going to re-build it. getting it ready to come home for the Winter make over....heres a few pics of the shop.
2005 Mustang
mrskydog
I had 2 1/4 Exhaust installed with a turbo style muffler. I also install a 1995 or so style Ranger 2.3 header. What I over looked was the small emisions ports below eack port.....UGG .(leaks Exhaust Bad!) I researched the board and yes I see I can tap and install a 3/8 st screw or possible 3/8 plug? I will get that done next week. I just over looked it I guess. I will get Exhaust cleaned up, do a complete brake job, then move on to the Winter gathering of parts to finish up in Spring.  Looking forward to the Big Columbus Ohio all Ford Swap meet on NOV.26 and again April 1st. :)
2005 Mustang
mrskydog
Just got back, and off it goes for Exhaust and brakes at my work place. Then I will start Fall/Winter restore for Spring 2012.
2005 Mustang
mrskydog
Went and changed out Oil in the Pinto today. I got the break-in oil out, then took it for a quick drive. It seems to drive out nice ,good power and shifting. On to Exhaust now, open header is a little noisy to fine tune. Here are a couple of quick Pic's. of today........Kirk
2005 Mustang
mrskydog
I have been very Lucky on finding Vintage parts for my Pinto Project> Today I picked up a Sport Steerig Wheel in Perfect Shape! ,just right. I will install this Tomarrow and then take it for its first Test Drive since the Engine Rebuild.  ;D I will post some pics later....Kirk
2005 Mustang
That paint is expensive because it's a custom blend thats put into a spray can & pressurized for convenience. If you were to buy it for spray gun use you could probably get a pint for $25 which would fill 4 or 5 spray cans.
I have this nifty spray can I got from Harbor Freight that you pour your own thinned paint in it, screw the cap on & pressurize with your air compressor & it turns anything into a spray paint.
mrskydog
I found the Rims and the Tires as a set, I bought them here in Michigan.  The owner had them for years, nice find for me. And I guess yes 25.00 a can for Spray paint that works well is Cheap ;) I am taking in for Exhaust now I think I am going with a 2" or to a 2" 1/2 pipei to a Small turbo style muffler.
Kirk
2005 Mustang
QuoteThe Color is Ford Tangerine for 1978..not cheap at about 25.00 a Can.
Price that in Canada: it will make you feel better !  :lol:
bbobcat75
thanks where did you have luck finding those tires sizes??
thanks
eric
1975 mercury bobcat 2.8 auto
mrskydog
Thanks...the Tires are P215/50D/13 frnt  and  P245/50D/13 rear.  The Paint is from a Paint Shop made by PPG Industries in a Semi gloss interior blend. One can was enough to cover shown panels. I included a Picture of paint can. It covers and looks great . I used this same paint to Dye the interior of my 73 Maverick.
2005 Mustang
bbobcat75
what size cragars are you running and the panels look awsome, would like to know what color and brand dye you used.
thanks
eric
JoeBob
What did you use to dye the panels? Mine could be brighter.
77 yellow Bobcat hatchback
Deuteronomy 7:9
mrskydog
Engine is in and runs great! all fresh and ready to go. I started to pull out some of the Interior Panels to re Dye since they were fadded. I also picked up a nice center Console and the SS Cragers,MickeyThompson 50's .....Going to be a Neat little car.
2005 Mustang
mrskydog
Motor is ready for break-in tommarrow, also found a set of Mickey Thompson Tires and Crager SS Rims for it :smile:
2005 Mustang
mrskydog
Today Ridge Ream the Block, and Hone Cylinders ,measure clearances and clean. Now ready to re-assmble. Got Wedding #2 this month in afew days in Milwaukee, so wont get it done and installed for about a week.
2005 Mustang
mrskydog
Quote from: Pinto5.0 on July 18, 2011, 07:06:44 PM
I love that orange interior. Thats only the 3rd one I've ever seen. I fell in love with my oddball black/gold combo in my '80 & it was the main reason I bought the car. Gotta love those odd ones....
Very Nice Car  I like the Odd  combos...Cool 8)
2005 Mustang
mrskydog
Getting close  assemble motor this weekend . Head complete , re-ring and bearings. got a Ranger manifold and modified it. Road test soon, I will update. ;D
I still would like to Install a Old School Intake set up for a 2.3 like Edlelbrock Ect.. anything out there? let me know. 8)
2005 Mustang
Hey, if you get-r-running and want to give it a good test run... you could consider a road trip for the September 11 weekend and join in some fun Pinto doings
here ~> http://www.pintostampede.com/events/911event.htm
or here ~> http://www.pintostampede.com/events/ohio.htm
I should be at the one in Illinois and love to see Pintos in all shapes, sizes and condition
mrskydog
My plan is to fix all Mechanical first, and start body work in a month or so. I like the Bright Tangerine paint , and going to stick with the org. color. I will start collecting odds and ends over the Fall and winter, rims, ect. I always injoy the Big all Ford Swap meet in Columbus Ohio in the Spring ,always alot of nice parts there.
Kirk
I forgot to add that the Low Compression was due to #3 piston both compression rings broken, as well as #1 had one broke ,and #2 had one broke. The only intact piston with rings was #4.
I know enginer at Sealed power Piston Ring called said due to the fact that the rings were broken at 180 deg ,center. Most likey caused by improper install, were the ring was installed without proper Tool and Snaked around to Install. This type of Install will  Fatiuge the ring in the center and will cause it to crack later. Good Info to Know.......Kirk
2005 Mustang
